Gtir Motorsport club » General Discusion » Gtir related Discussion » Lambda sensor
Lambda sensor
1 Lambda sensor on 4th January 2016, 10:58 am
How many lambdas do these things have? my mot failed due to the lambda being ripped out and a hole left, when i took into the exhaust place they plugged the hole and said it looks like it had just been removed, weird as my emissions passed, so is there more than 1 sensor in the exhaust?
the hole was in the centre section before a silencer. turns out my downpipe wasnt even an issue :/
2 Re: Lambda sensor on 4th January 2016, 11:21 am
There is one lambda in the turbo elbow. The other sensor could be the catalytic convertor sensor which senses temperature and if hot will eluminate a bulb on your dash to warn you its hot so you dont park on grass and set fire to it? Pretty dumb
Find a better MOT tester lol
3 Re: Lambda sensor on 4th January 2016, 11:26 am
It always makes me laugh about the bulb on the dash to warn you not to park on grass and set fire to it Laughing
4 Re: Lambda sensor on 4th January 2016, 11:30 am
Yeah to go along with the umbrella and air con and all the other weird refinements on a "rally" car haha
5 Re: Lambda sensor on 4th January 2016, 12:27 pm
Or a wideband sensor ....was fitted and taken out ...
6 Re: Lambda sensor on 4th January 2016, 12:42 pm
wrc
Standard the only 'lambda' is in the downpipe.
The sensor near the cat is a cat temp probe and bears no odds to emissions and/or running of the vehicle.
7 Re: Lambda sensor on 4th January 2016, 1:51 pm
thanks guys that makes sense, its plugged now and sounds great Smile so dont really need to replace it?
8 Re: Lambda sensor on 4th January 2016, 2:09 pm
Nope you should be good! You will see the lambda if you look down by the dip stick entry and the plug its on the turbo elbow :-) anything else is not really needed although a hole is never good so as you have done plug it up :-)
