Gtir Motorsport club » active members adverts » Parts Wanted » Front ABS sensors (both sides)
1 Front ABS sensors (both sides) on 4th January 2016, 10:04 pm
Please PM me if you any?
Cheers
Neil
2 Re: Front ABS sensors (both sides) on 5th January 2016, 1:25 am
Think I may possibly have o/s maybe n/s too but need to check
3 Re: Front ABS sensors (both sides) on 5th January 2016, 6:20 pm
Hi Cosmic, have a look at this.
http://www.gtir-motorsport-club.com/t430-abs-sensor?highlight=abs+sensor+repair
Easy repair - with a bit of soldering - and you could probably do it without taking the sensor out of the hub. The wire always breaks in the same place, but it's inside the cable so you can't see it...
I've been driving on repaired ones for 2 or 3 years now.
Good luck
4 Re: Front ABS sensors (both sides) on 5th January 2016, 8:30 pm
Hey John, i think i read this post a while back but didnt put two and two together,
Both My sensors have sheared at the same place, been repaired with leccy tape but sheared again.
Thanks for reminding me of this post, ill give this more robust repair a try this weekend.
Very Happy
