Gtir Motorsport club » General Discusion » Gtir related Discussion » Flexi Exhaust Pipe
Flexi Exhaust Pipe
1 Flexi Exhaust Pipe on 5th January 2016, 7:51 am
I did some searching and couldn't find the answer I needed.
Is there a difference between short and long flexi pipes?
I want to run a short one like below. My exhaust has a long one atm and its torn to pieces from scraping on speed bumps etc. Its the second one ive replaced for this reason....
2 Re: Flexi Exhaust Pipe on 5th January 2016, 8:45 am
If it has a long one on it already its probably been cut to that length so i doubt your be able to use a shorter one ...
3 Re: Flexi Exhaust Pipe on 5th January 2016, 9:14 am
I dont mind adding another section of 3inch pipe in there, I guess the only difference in flexi lengths would be the amount of movement in the joint.
4 Re: Flexi Exhaust Pipe on 5th January 2016, 9:16 am
^ basically yes ...
5 Re: Flexi Exhaust Pipe on 5th January 2016, 10:11 am
Thanks mate Smile
6 Re: Flexi Exhaust Pipe on 5th January 2016, 12:12 pm
The top one I would use only for heat related movement like an external gate dump pipe. The second would be better. Remember a transaxle engine has more exhaust movement than a rwd so when it's fitted make sure it's not under pull tension when fitted. As when the motor moves it will try stretching the exhaust beyond its limits.
7 Re: Flexi Exhaust Pipe on 5th January 2016, 9:08 pm
Thanks for the advice Nigel, much appreciated Smile
