Gtir Motorsport club » Tech room » Help and Advice » Wheel bearings
Wheel bearings
1 Wheel bearings on 8th January 2016, 8:15 pm
Rscozzy
Best place to get wheel bearing (front)
2 Re: Wheel bearings on 8th January 2016, 9:15 pm
Front and rear are the same anyway..
3 Re: Wheel bearings on 8th January 2016, 9:43 pm
http://www.importcarparts.co.uk/parts-info?id=1442&cat=87&sub=119&sec=0&var=0&dc=&gen=&searchKey=&searchPart=
4 Re: Wheel bearings on 9th January 2016, 8:22 am
any local bearing shop will have them too, if getting from icp check what make they are as they supplying optimal brand a lot these days & that all made in china & while ok japan quality brands can be had for same money or just a few pound more.
5 Re: Wheel bearings on 7th April 2017, 1:34 pm
R failed it's MOT on handbrake (which i knew it would) and front wheel bearing.
Found this one at ICP and looks good value
http://importcarparts.co.uk/parts-info.asp?id=1442
These look like double (back to back) tapers, so you don't have worry about setting pre-load.
Is it just a simple case of pulling of the old bearing, and pressing in the new, then tightening up the end nut? study
Also is it worth doing both sides at same time?
6 Re: Wheel bearings on 7th April 2017, 4:01 pm
I wouldnt say its essential to do both sides at the same time really its not like shocks and springs etc .... if you wanted to do it for piece of mind you could but dont reckon its that crutial niel ...
7 Re: Wheel bearings on 7th April 2017, 4:02 pm
And yes just like any other bearing really .....
8 Re: Wheel bearings on 7th April 2017, 4:09 pm
Cheers Leighton Very Happy
9 Re: Wheel bearings on 7th April 2017, 5:23 pm
Hey Neil did it fail on play or being rough?
If it's just a play try to tighten up hub nut
10 Re: Wheel bearings on 7th April 2017, 5:52 pm
Excessive play Mike,
The picture looks  like the bearings don't separate, so I've bought 2 new ones from ICP for £60
Just looked a bit more into it and i think they do separate, eg outer race and rollers, so yes i could prob nip them up.
I'll try that this weekend as it sounds like a quick fix.
11 Re: Wheel bearings on 7th April 2017, 5:57 pm
@Cosmic73 wrote:Excessive play Mike,
This is why i asked if they need preload.
Sometimes for some magical reasons hub nut can get slightly loose... Especially on bloody Renault and blasting them with airgun is enough. But there again 60 quid doesn't require a kidney sale...
12 Re: Wheel bearings on 7th April 2017, 5:59 pm
Yeah, at least i can store them for when they are needed
13 Re: Wheel bearings on 7th April 2017, 6:05 pm
Oh and check other stuff arond the hub... Sometimes your strut bolts might come loose and dumb tester might think it's a bearing... Bloody idiots they're those testers..... lol!
14 Re: Wheel bearings on 7th April 2017, 8:41 pm
@Gostek wrote:Oh and check other stuff arond the hub... Sometimes your strut bolts might come loose and dumb tester might think it's a bearing... Bloody idiots they're those testers..... lol!
Yeah I find those European ones the worst they are out to get us now we voted to leave the EU it wasn't all of us yoursofunny I will miss Polish sausage when we leave. I sent a letter to Boris Johnson explaining my displeasure but never got a reply. Think I said Sausage too many time in the letter.
15 Re: Wheel bearings on 7th April 2017, 8:56 pm
Oooooerr Laughing
16 Re: Wheel bearings on 8th April 2017, 7:44 pm
So bought a 32mm socket from Halfords and tightened the hub nut, but theres still play.
So ill have to replace the bearing after all.
Are they easy to remove? Suspect
17 Re: Wheel bearings on 8th April 2017, 8:01 pm
Depends on what tools you have .. do you have a press or such like ???
18 Re: Wheel bearings on 8th April 2017, 8:07 pm
Undo hub nut make sure drive shaft isnt siezed in hub Remove caliper hang up on strut with cable tie undo track rod end and lower ball joint undo two strut bolts then you got the whole assembley off on the backside you will see a dust cover remove that and should see snap ring remove then its ready to be pressed out....
19 Re: Wheel bearings on 8th April 2017, 8:10 pm
Or if your doing with a push/pull puller style tool you can leave it all attached minus the caliper there is just enough room to pull the shaft out and do it all in place .... as i did mine .
20 Re: Wheel bearings on 9th April 2017, 6:47 pm
Oh mate since Brexit I'm on the mission piss taker
21 Re: Wheel bearings on 9th April 2017, 6:53 pm
@nomad wrote:Undo hub nut make sure drive shaft isnt siezed in hub Remove caliper hang up on strut with cable tie undo track rod end  and lower ball joint undo two  strut bolts then you got the whole assembley off  on the backside you will see a dust cover remove that and should see snap ring remove then its ready to be pressed out....
Thanks Leighton,
I read your guide on replacing CV joints, that was a great write up btw.
I only have a small bearing puller, not a press so I'll have to take it to work Very Happy
22 Re: Wheel bearings on 9th April 2017, 8:07 pm
Your welcome mate ..... i should do more how to's really just trying to save up a few quid to start back up the pulsar project as ive neglected it for to long as had no money so once i get back to it il do a few more fingers crossed ..... you can do it with a puller ....
23 Re: Wheel bearings on 22nd April 2017, 11:26 am
So i managed to remove the bearing (or most of it) however an inner race stayed stuck on the shaft!
The gap is too small for a bearing puller. I tried heating it but just burnt my hand Evil or Very Mad
Will I have to grind this off? scratch
24 Re: Wheel bearings on 22nd April 2017, 11:29 am
I do... At work I've go air chisel so I'm only making small diagonal cut and shock it till it'll crack... You could try to cut it fairly deep and wack it with hammer and chisel...
25 Re: Wheel bearings on 22nd April 2017, 11:50 am
Just grind/cut 2 slots in lower race lip for a 2 leg puller or use a bearing separator clamp .
You can grind it at a diagonal and chisel or gas axe it too if no pullers available .
