Gtir Motorsport club » Tech room » Help and Advice » Wheel bearings
Wheel bearings
26 Re: Wheel bearings on 22nd April 2017, 1:09 pm
Just popped into a local garage and he removed it in 30seconds! Just chiselled it straight off.
27 Re: Wheel bearings on 22nd April 2017, 7:40 pm
Just done my wheel bearings took about 1 1/2 each side form start to finish not as big a job as I feared will be doing my other bearings soon whilst all my tools are out lol
28 Re: Wheel bearings on 22nd April 2017, 8:17 pm
Can be pain, it my younger days I foolishly grinded right through one lol
29 Re: Wheel bearings on 22nd April 2017, 8:55 pm
Its one of those things they can come out without to much hassle with a few taps or fall apart and end up trying to grind the inner part off the drive shaft and trying to get the outer part out if the hub with nothing to get a purchase on other than where the ball bearings sit ....
30 Re: Wheel bearings on 22nd April 2017, 9:21 pm
the hub bearing puller kits and a 2 leg puller/bearing clamp set makes easy work of fwd style bearings and other bearing jobs
You can use the kits on car to remove and refit bearing (saves fitting damage errors) and also can make a puller plate up so can pull centre spindles too with the screw rod (can slide hammer those but it a bit rough if they tight). I used kit on subarus mainly but done the nissan with it also. basic kit about 45GBP roughly for unbranded set . For less than 100GBP you could have enough puller equipment handle most wheel and gearbox bearing and engine needs etc .
31 Re: Wheel bearings on 25th April 2017, 6:23 pm
Pressed on the new bearing at work and one the seals is loose even tho it's fully inside the hub. Eg when you turn the shaft, it turns the seal too.
FFS, why is it always me!
I've squirted some thread lock into the gap and hoping that'll fix it.
32 Re: Wheel bearings on 25th April 2017, 6:39 pm
Silicone probably would of held it better ...
33 Re: Wheel bearings on 25th April 2017, 7:00 pm
Is this a common problem?
If the thread luck doesn't hold I'll use silicon.
34 Re: Wheel bearings on 25th April 2017, 8:00 pm
If it was a optimal wheel bearing kit I not surprised as it china junk .
If buy the Jap bearing kits it fits like oem .
35 Re: Wheel bearings on 25th April 2017, 8:02 pm
This was a cheapy ICP bearing, oh well, live and learn Very Happy
36 Re: Wheel bearings on 25th April 2017, 8:26 pm
The oem Jap bearing kit is only about £30 from bearing suppliers, ICP can do the Jap ones too if ask but thee fookers seem got liking for cheap optimal bearings with the bullshit germany branding. Difference is night and day if compare finish and tolerances, even by eye you can see the leap in quality of the Jap bearing kits.
37 Re: Wheel bearings on 25th April 2017, 9:13 pm
I didn't even think to check that after fitting my bearings, oh well now lol
38 Re: Wheel bearings on 28th May 2017, 3:36 pm
92pulsar
92pulsar
skf part numbers is fw114 91 sentra bearings are the same
39 Re: Wheel bearings on 27th October 2017, 8:20 am
SIR GTI-R
SIR GTI-R
Man ive had no end of issues with my LHF I cant get 6 months out of them ive replaced carriers drive flanges even bought a brand new Autech drive flange with a Nissan sourced bearing and New CV didn't even get 4 months before I got play in it again
you guys got any thoughts only thing I haven't changed is the driveshaft which ive got 1 waiting in the shed off a abs model if I swap the outter cv over will it work you think?
40 Re: Wheel bearings on 27th October 2017, 9:50 am
how tight are torqueing the driveshaft nut?
41 Re: Wheel bearings on 27th October 2017, 5:30 pm
Is there a problem with the hub
42 Re: Wheel bearings on 27th October 2017, 6:43 pm
Are you running any camber on them at all ..
43 Re: Wheel bearings on 27th October 2017, 8:44 pm
What's the tracking like, what wheel like, what brake like ... could be way you fitting bearing perhaps !
