Gtir Motorsport club » General Discusion » Gtir related Discussion » Anyone running a GTX range Garrett?
1 Anyone running a GTX range Garrett? on 15th January 2016, 5:16 pm
ckd281081
I'm considering going down the GTX road for my turbo choice, but the figures quoted by Garrett seem awful high (640bhp or so from a 3076r and 560bhp from a 3071r). Is anyone running anything from the GTX range?
Cheers
2 Re: Anyone running a GTX range Garrett? on 18th January 2016, 6:40 am
I've use gtx 2867 & 2871 . nice spec turbos & simple fitment plus prices can be reasonable on these new. Had good results with them but top rated hp not really achievable for most sr20 builds. When running bigger power & using custom manifolds plenty of other options are available, 30 & 35 hta range is good well used options too .
3 Re: Anyone running a GTX range Garrett? on 6th February 2016, 12:51 pm
ADSgtir
I'm using a 2871 GTX however it's a variant on the stock GTX turbo , seems to be a mighty fine unit , made 337 bhp @1 bar in preliminary mapping , it has also been done to hold and run high boost at higher rpms .
I have not tried on the road yet but reports so far indicate it's works very well , the car is with Bob so he could say how it is on the road , I have not seen anyone else using this unit but it looks good so far
4 Re: Anyone running a GTX range Garrett? on 6th February 2016, 4:39 pm
What about price ?????
5 Re: Anyone running a GTX range Garrett? on 6th February 2016, 7:23 pm
@ADSgtir wrote:I'm using a 2871 GTX however it's a variant on the stock GTX turbo , seems to be a mighty fine unit , made 337 bhp @1 bar in preliminary mapping , it has also been done to hold and run high boost at higher rpms .
Was just about to post a reply regarding your turbo Allen but you beat me to it lol.
Btw welcome to our forum welcome
As said i have just mapped the car at a very safe level after carrying out engine swap and other modifications so will up the boost at a later date.
Our resident mapper 'Terry Dolphin' checked the map I did and said it was pretty much spot on with scope for more power at the given 1bar by adding a bit more ignition it could have seen high 340s with good torque also (im just playing on safe side for time being). So quite a compliment from the legendary Mr Dolphin who's teaching me more every time he is here and really getting the knack of this mapping now but still lots to learn.
Took car on a test drive yesterday and must say im very impressed. ive driven many cars with 2871r tubby's over the years' but this thing pulls so hard and comes on boost early with next to no lag. I capped rev limit to 7200 for time being until other small issues are resolved but when it comes back for the final big power map Im intrigued to see what this car will make at 2 bar boost as I have no idea but the results so far are very promising and AET who custom spec'd this turbo are not giving any figures but I reckon it will knock the gt2871r into tomorrow with its overall power and the speed it spools too
spec:
Aet's own custom turbo(modified from 2871r)
z32 maf, 800cc injectors, fmic, quaife g'box (water/meth injection to be added), mapped on Apexi power fc
previously mapped by last uuum! well known tuner at same 1bar boost (same turbo) car made just over 300bhp at SRR prior to engine saying night nights after severe borewash.
I did 1 run on our dyno with the same map prior to wiping it and starting afresh, she made 306.8bhp but was severerly overfuelling which was very apparent as ex fumes were eye watering
So in answer to your question Colin deffo worth a word with Aet regarding their custom gtx spec tubbys Wink
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
6 Re: Anyone running a GTX range Garrett? on 6th February 2016, 11:00 pm
ADSgtir
From what AET have told me the unit has their own compressor , its based on the GTX and is a billet compressor , the turbine wheel is modified and has been clipped , how much and what angle ,only they would know .
the clipping is done to remove some of the blade and reduce restriction at higher rpms , this allows the engine to pick up faster at high rpms and to keep the flow high at the high rpms ,so the turbo keeps flowing at the top end and holds boost ,
cost wise is similar to the GTX 2871r .
Its another option thrown into the mix for pulsar owners , and I will see what I can get out of it .....
