Gtir Motorsport club » Tech room » Help and Advice » altenators in the cold?
26 Re: altenators in the cold? on 21st January 2016, 6:31 pm
Funny readings loss of charge says earth to me
27 Re: altenators in the cold? on 22nd January 2016, 9:23 am
im going to have a look at the car tomorrow, take wheel off and check the pulley and also change the altenator belt (i couldnt get one in time when i done the altenator so gonna just do it and see if it makes any difference, if not then its done anyway).
Does anyone have the part numbers for the belt with aircon, or the size? as the motor factors doesnt have them on system.
28 Re: altenators in the cold? on 22nd January 2016, 10:17 am
29 Re: altenators in the cold? on 22nd January 2016, 10:21 am
Just found these part numbers on the net.
Bosch 4pk845 or 4pk830
nissan ay140-40830
halfords 845e
goodyear 6pk0837
30 Re: altenators in the cold? on 22nd January 2016, 10:26 am
cheers stu, that link is for aircon removed, mine is still in so the numbers you posted are for the air con in yeah?
31 Re: altenators in the cold? on 22nd January 2016, 10:38 am
Nope, air con in is 6PK1035 and Power steer/Water pump is 4PK919/920
32 Re: altenators in the cold? on 22nd January 2016, 11:25 am
@splmum wrote:Nope, air con in is 6PK1035
Cheers ill get one of these ordered
33 Re: altenators in the cold? on 22nd January 2016, 12:32 pm
Ah sorry about that. I automatically thought the aircon would have been removed..
34 Re: altenators in the cold? on 23rd January 2016, 3:41 am
Don't think need to be sorry, it is all relevant information that somebody else will maybe benefit from.
Me in particular, I didn't know the length of the belt for no air con, I do now Smile
35 Re: altenators in the cold? on 23rd January 2016, 5:11 pm
Yeah crank pulley has split
36 Re: altenators in the cold? on 23rd January 2016, 5:25 pm
@splmum wrote:Don't think need to be sorry, it is all relevant information that somebody else will maybe benefit from.
Thanks Gaz Smile
MrB you was spot on with your diagnosis yet again Smile
You shoukd atleast get a rep point if not a thankyou Laughing
37 Re: altenators in the cold? on 23rd January 2016, 5:50 pm
Yup rep and thank you for the help, and everyone else, if i have to buy from nissan is the bolt and washer needed or can i reuse my old one?
38 Re: altenators in the cold? on 23rd January 2016, 5:56 pm
Use the old ones Wink
39 Re: altenators in the cold? on 23rd January 2016, 6:01 pm
It's a team effort here .
bolt & washer can be reused, you probably wise pull it off to check keyway key ok &bolt/washer good & correct. so many cars been bodged so wise check prior to doing ordering.
They got pulley in UK/EU stock !
We have companies here that can re-manufacture the pulley (about 40gbp) go new oem myself though while still available.
40 Re: altenators in the cold? on 23rd January 2016, 6:10 pm
Ill probably have to put this into a garage as i just cant get the bolt lose at all
41 Re: altenators in the cold? on 23rd January 2016, 6:22 pm
Put some elbow grease into it Sye lol
Found this on the net Smile
http://www.frsport.com/Nissan-12303-54C00-OEM-Crank-Pulley-Damper-SR20DET-RNN14-Pulsar-Sunny-GTiR_p_59960.html
Cheaper than Nissan Wink
42 Re: altenators in the cold? on 23rd January 2016, 8:15 pm
Impact wrench or a breaker bar does the trick ...they can be tight ...
43 Re: altenators in the cold? on 23rd January 2016, 9:12 pm
If you can't get it off I can possibly post you some grease they use in the airforce to get bolts undone
44 Re: altenators in the cold? on 24th January 2016, 9:38 am
Well i dunno if elbowgrease is useful as the pulley just keeps turning, anyone know the size of the bolt so i can grab a socket for my breaker bar (having to use an adjustable spanner).
Also grabbed the tool mr b recommended for pulling the pulley off
45 Re: altenators in the cold? on 24th January 2016, 2:44 pm
well got the bolt off, just cranked engine and it freed it off, took a couple of attempts but we hav the bolt out, will have to waig for the tool and a new pulley.
another question i had a look but cant really see how to get the pas belt off?
46 Re: altenators in the cold? on 24th January 2016, 3:28 pm
Bolt on tensioner that locks it in position  left side as you look at it from the front then slacken the adjuster. One goes oppersit way to what you think sure it's adjuster on there
47 Re: altenators in the cold? on 24th January 2016, 10:52 pm
Here ya go
https://drive.google.com/file/d/0B7Ub2apq5-pfU29GVnQxdU5ibUE/view?pref=2&pli=1
Thanks Mr B, these are REALLY helpful Very Happy
48 Re: altenators in the cold? on 25th January 2016, 8:31 am
@splmum wrote:Here ya go
thanks very much, those lineart drawings are really terrible but i will have a look when im at the car to try and work with it.
Thanks again Cool
49 Re: altenators in the cold? on 25th January 2016, 8:43 am
They are not the clearest but give you an idea ... better than stabbing in the dark lol ...
50 Re: altenators in the cold? on 28th January 2016, 9:13 pm
Well got it all back together and everything is working now, boost is still not however.
Thanks everyone for the help on this really appreciated.
