Gtir Motorsport club » Tech room » Help and Advice » No boost
No boost
1 No boost on 19th January 2016, 7:32 pm
Hehe another issue im trying to pinpoint is the car has no boost anymore, when the turbo kicks in all i get is a lack of power and a loud sucking sound, i thought it might have been the dump valve but removed that and blocked it off but still the same issue, anyone got any ideas on where to check?
2 Re: No boost on 19th January 2016, 9:38 pm
luke s
Are you sure your wastgate isn't open? Check you actuator, are you running a standard set up ext?
3 Re: No boost on 19th January 2016, 9:44 pm
Is it smoking or anything .... intercooler pipes all good ????
4 Re: No boost on 19th January 2016, 11:16 pm
Ill check my intercooler pipes, no smoke just a slight misfire when boost does come in, i let off when that happens
5 Re: No boost on 19th January 2016, 11:20 pm
luke s
I'd check all your boost pipes and clamps bud
6 Re: No boost on 19th January 2016, 11:23 pm
Did it happen suddenly? Did something happen before it happened. Were you on boost and then all of a sudden no boost..?
Have you worked on anything lately?
7 Re: No boost on 19th January 2016, 11:28 pm
@luke s wrote:Are you sure your wastgate isn't open? Check you actuator, are you running a standard set up ext?
Im running an avcr set at 1bar so not standard
8 Re: No boost on 19th January 2016, 11:30 pm
Ive not worked on anything in that area, only trackrod end, yeah it just sort of suddenly happened...after it was re-motd
9 Re: No boost on 19th January 2016, 11:33 pm
You wasn't on boost when it happened?
10 Re: No boost on 20th January 2016, 7:59 am
Would AVCR solinoid cause this ?
11 Re: No boost on 20th January 2016, 8:06 am
Well it only happens on boost, drive fine when not on boost, so only way i can test to see if it still happens is to come onto boost slightly
12 Re: No boost on 20th January 2016, 8:35 am
You also got this elec power issue so if wiring bad somewhere it could be causing low voltage to fuel pump & avc perhaps !
13 Re: No boost on 20th January 2016, 8:59 am
I done a sensor check on the avcr and the sensors read bost = 1.2v (i dont know what that means).
Im going to put it into an electrician next weekend, only wiring i changed was the fuse on the headlight loom, cut it back and replaced one of the fuse holders which was melted.
