Gtir Motorsport club » General Discusion » Gtir related Discussion » Crankcase breather pipe size
1 Crankcase breather pipe size on 22nd January 2016, 1:03 am
Does anyone have a metal crankcase breather pipe removed from a block at the moment?
Im interested to know the diameter of pipe that goes into the block?
Basically im trying to figure out if this 5/8 press in breather fitting (that is intended for the rocker cover) will also work in the block.
A rep point is waiting for you Laughing
2 Re: Crankcase breather pipe size on 22nd January 2016, 2:48 am
Won't work. There won't be enough room to connect a fitting when the head is on. Your better off welding a steel male barb to the stock unit.
Give me my rep point now
3 Re: Crankcase breather pipe size on 22nd January 2016, 2:59 am
That's most annoying. Funny you mention that because now I remember my engine builder forgot to put mine in, I had to cut the pipe down to fit it with the head on.
Rep point for your annoyingly correct answer Laughing
