Gtir Motorsport club » Tech room » Help and Advice » Forged oil catch tank
1 Forged oil catch tank on 23rd January 2016, 10:59 am
Rscozzy
Getting a lot of creamy white gunk in rocker cover and catch tank not sure if have got it piped correct
T piece on right of rocker 1 going to catch tank other blank off then 1 from catch tank going to right off engine block then 1 from catch tank going inbetween turbo and air filter
Other side of rocker is blanked off
2 Re: Forged oil catch tank on 23rd January 2016, 11:04 am
You got an actual picture ???
3 Re: Forged oil catch tank on 23rd January 2016, 11:23 am
Rscozzy
https://2img.net/h/i1138.photobucket.com/albums/n540/rscozzy/8DA3C269-4181-4F17-B967-2FB9D07089DC.jpg
4 Re: Forged oil catch tank on 23rd January 2016, 11:36 am
Rscozzy
Not sure if link works
5 Re: Forged oil catch tank on 23rd January 2016, 12:00 pm
6 Re: Forged oil catch tank on 23rd January 2016, 12:12 pm
Rscozzy
Any help appreciated thanks
7 Re: Forged oil catch tank on 23rd January 2016, 12:22 pm
Thats piped up wrong!
You need the blanked off part of t-piece going to where the catch can goes back into the block at right front.. it also needs the factory valve pipe back in.
Your pipe into catch can off the t-piece us fine but then you need a small filter on the other outlet of catch can to vent to atmosphere ; )
8 Re: Forged oil catch tank on 23rd January 2016, 12:24 pm
So in short. That left pipe in the picture that is going to the block. Remove it from the catch can and connect it to the t-piece.
9 Re: Forged oil catch tank on 23rd January 2016, 12:27 pm
Rscozzy
What's factory valve pipe any photos
10 Re: Forged oil catch tank on 23rd January 2016, 12:33 pm
Its the short hose that conected to the factory oil seperator.
I havent got a picture at the moment.
I have only recently been told that it needs to be in place. Been told it causes the car to not idle properly if it isn't in place.
Mine needs to be put back on also as its been removed at some point..
11 Re: Forged oil catch tank on 23rd January 2016, 2:48 pm
12 Re: Forged oil catch tank on 23rd January 2016, 3:00 pm
I don't use my car daily so I don't return the bottom of forge catch can back into block as I find it dose get conden in and puts gunky White oil back into engine which is not good
13 Re: Forged oil catch tank on 23rd January 2016, 3:27 pm
Rscozzy
what about the 1 on back left of rocker cover
14 Re: Forged oil catch tank on 23rd January 2016, 3:44 pm
This is how mine is fitted
I don't have the oil separator fitted nor has been on my last few gtirs not noticed any idling problems
15 Re: Forged oil catch tank on 23rd January 2016, 3:44 pm
@Rscozzy wrote:what about the 1 on back left of rocker cover
Mine is blocked off but I plan on putting the oe setup back on sometime. That also has a valve in the outlet.
The way your setup is at the moment I wouldnt bank it off because I guess it will cause crank case pressure to rise!
You need it to vent off to atmosphere somewhere..
16 Re: Forged oil catch tank on 23rd January 2016, 3:48 pm
robd wrote:This is how mine is fitted
Personally I wouldnt run it like this!
You will run the condensation straight into the block nd cause water to mix with the oil..
You need the catch can to vent off rather than return it back to the block as said above.
The other breather needs to be re comissioned on the t-piece and run back into the block..
17 Re: Forged oil catch tank on 23rd January 2016, 4:04 pm
Rscozzy
Is this any better https://2img.net/h/i1138.photobucket.com/albums/n540/rscozzy/59914988-843E-4719-92D8-5FE58EB26FF7.jpg
18 Re: Forged oil catch tank on 23rd January 2016, 4:04 pm
Rscozzy
If no any pictures of setups might help cheers
19 Re: Forged oil catch tank on 23rd January 2016, 4:23 pm
@Rscozzy wrote:Is this any better https://2img.net/h/i1138.photobucket.com/albums/n540/rscozzy/59914988-843E-4719-92D8-5FE58EB26FF7.jpg
Where you have put the filter on the bottom of the catch can. I would remove it and cap it off. Oil will run out of there..
You have it plumbed into the standard induction pipe so I think that should be fine because it will draw the vapours into your induction...
The other pipe from t-piece to block is good yes but you need to get the oe restrict or pipe..
20 Re: Forged oil catch tank on 23rd January 2016, 4:30 pm
Rscozzy
Cheers going to look on eBay for ristrictor pipe
21 Re: Forged oil catch tank on 23rd January 2016, 6:40 pm
Rscozzy
Can I put a small filter on left side of rocker
22 Re: Forged oil catch tank on 23rd January 2016, 6:58 pm
Yes
23 Re: Forged oil catch tank on 23rd January 2016, 7:22 pm
It's upside down filter needs to be at top
24 Re: Forged oil catch tank on 23rd January 2016, 7:27 pm
It does vent to atmosphere
It's been on the car for over 10 years and engine has never need a to be rebuilt and is still going strong had same system on a few cars and never had a problem
25 Re: Forged oil catch tank on 23rd January 2016, 7:38 pm
Oh yeah sorry. I didnt see that small filter in the catch can.
