Gtir Motorsport club » General Discusion » Random banter » Spot whats missing competition
1Spot whats missing competition Empty Spot whats missing competition on 24th January 2016, 7:22 pm
So i got my block back after being rebored last week.
Thought id start reassembling it, but wait, my cunning GTIr nose sniffs something amiss, something i cant quit put my finger on.
A slight shift in the space time continium, but what is it?
Somethings been removed, in fact somethings been removed and not put back on, no wait, somethings been removed and not put back on and not given back to me and they havent f&£ing told me!!!!
Twats! Wheres my piston squirters and oil baffle, for Christs sake.  censored  censored  censored  censored
Spot whats missing competition Image_zpsprr6jv2o
2Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 8:13 pm
Bastards! fuming
3Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 8:24 pm
Nightmare
4Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 8:33 pm
Thing is i was chuffing close to rebuilding it and had no idea till i noticed it on a photo from a month back.
I wonder how builds are stuffed from the start cos some monkey removed a tiny pin or screw and said nowt,
Shocked
5Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 9:09 pm
It's not something what you can pick up from local tesco too
6Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 9:12 pm
A lot of these engineering places are sloppy & quite clueless, hope they not lost them !
After you clean up block face I would wash that block out with hot soapy water & a hose.
7Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 11:28 pm
A bit sloppys right, ill phone them tomorrow and find out where they are, if they lost them then they'll have to sort it out and it will be a real ball ache for them.
Luckily i still have my old scrap block with the bits i need, but i aint gonna tell them that. Twisted Evil
8Spot whats missing competition Empty Re: Spot whats missing competition on 24th January 2016, 11:35 pm
Its not the point though as its the principal of it .... hopefully that doesnt reflect on the level of the workmanship done on the block Wink
9Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 11:02 am
^ lets hope not but they couldn't check the block deck well with all that gasket residue left on or cleaned block much.
I normally have the shop do a minimal depth resurface on block & end cover with a nice smooth glassy finish (not grainy milling lines) when using metal layer gaskets, you can get away with poorer finish on composite gaskets
Double check & check again everything as building it up as if a first sr20 & first time using shop services a lot of mistakes are possible & many times by people you paying :-/
10Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 11:12 am
I'm definitely going to double check everything,Mad
The annoying thing is i really dint want to use them but there is simply no-where else around Coventry. Neutral
11Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 11:45 am
Yes, the shop I took mine to told me to take everything off before I gave it to them. I guess it's their way of avoiding that sort of issue..
12Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 12:20 pm
that's true to be fair you are supposed to entirely strip the block before handing it to them.
But they should have tied a bag to the block and gave the bits back to you
13Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 2:16 pm
That's a fair point i suppose and i know for next time.
I phoned them just now and they have the squirters,
Swear blind that the baffle plate wasn't fitted tho,  Shocked
Anyway live and learn. Very Happy
14Spot whats missing competition Empty Re: Spot whats missing competition on 25th January 2016, 3:13 pm
Yeh experience with the shop makes a difference that's why a first time build can be a ball ache.
Shop I use has little issue with parts left on & notes it on job sheet when go in.
To do a lot of good accurate machine work they need caps bolts, shells, front cover etc so should have no issue keeping parts together.
Least you got spares ...
