Gtir Motorsport club » General Discusion » Gtir related Discussion » takes about 7 attempts to start
1 takes about 7 attempts to start on 4th February 2016, 6:13 pm
joetheeskimo
So my car has been sat for nearly a year now. 9 month with a new/2nd hand engine
Ever since the engine has been in it takes about 7 attempts to start. First 3 attempts it will start then just cut out after 1 to 2 seconds of running next few attempts it runs but is more lumpy and if you give it ant revs it cuts out. After about 6 or 7 try it will start and idle fine.if you the turn it off and try again it fine. If however you leave it for halt or a whole day you have to go through the above 6 or 7 times again before it will start and ideal ok.
Any ideas what this could be.
Thanks
2 Re: takes about 7 attempts to start on 4th February 2016, 6:43 pm
Old fuel?
Dirty plugs?
Furred up terminals in dizzy cap?
Congeled fuel in fuel filter?
3 Re: takes about 7 attempts to start on 4th February 2016, 6:45 pm
How long have you had it ticking over for? Have you got it upto temperature yet?
4 Re: takes about 7 attempts to start on 4th February 2016, 7:14 pm
I was going to say fuel and filter, dizzy a good place to look as well
5 Re: takes about 7 attempts to start on 4th February 2016, 7:46 pm
Check spark. Fuel struggling. Dose it prime ok before you turn the key ? wounder if it's like air locking or intank filter blocking up. Take fuel pipe off rail and see how much it puts into a  bottle.
6 Re: takes about 7 attempts to start on 4th February 2016, 8:30 pm
joetheeskimo
I will check these things. I belive it could be old fuel as the fuel was sat in the tank for 6 months before starting it.
When ignition is turned on you can hear the pump priming. I do not have the charcoal canister any more.
I try to get the running at least once a week and allow it to get warm and run for about 10-15mins.
I will change the fuel filter and also clean the plugs and see if that helps.
Thanks
