Gtir Motorsport club » Tech room » Help and Advice » Torque specs for knock/DET sensor
1 Torque specs for knock/DET sensor on 6th February 2016, 11:19 am
Hardy172cup
As above what's the correct torque specification to tighten the knock sensor with?
I know they can be very funny with being over or under tightened so want to make sure it's torqued up correctly.
Cheers
2 Re: Torque specs for knock/DET sensor on 6th February 2016, 11:40 am
You checked the wiring to airflow meter I had a car that was coming up with det on the fault checker think it eventually turned it to be faulty wiring bad earth or something like that
3 Re: Torque specs for knock/DET sensor on 6th February 2016, 11:52 am
Hardy172cup
I have tried using a different MAF in the past but since fitting the new DET sensor things seem rather different with the way it's acting so might be worth me checking it again. Cheers for the advice mate
4 Re: Torque specs for knock/DET sensor on 6th February 2016, 6:24 pm
Knock SensorĀ
15-20 ft-lbs
5 Re: Torque specs for knock/DET sensor on 6th February 2016, 6:29 pm
Hardy172cup
@nomad wrote:Knock SensorĀ
15-20 ft-lbs
Cheers for that.
6 Re: Torque specs for knock/DET sensor on 6th February 2016, 7:52 pm
Your welcome fella....
