Gtir Motorsport club » General Discusion » Random banter » GTR35 gearbox issues again
1GTR35 gearbox issues again Empty GTR35 gearbox issues again on 17th February 2016, 9:48 pm
well after my last nightmare I finally got the car running correctly and gear selection was spot on after partially stripping, cleaning and reassembling the solenoid packs etc.
Far better than it ever had been since I purchased the car around 4 years ago so was well chuffed Smile
anyway a few months down the road now have a further issue with clutch slip and stalling car when trying to engage/select park so back on the lift the car goes Rolling Eyes
Have now found a further issue.........basically the very expensive hydraulic oil has now decided to mix with coolant leading to a mayo coloured mess scratch
So on further investigation have discovered that an o ring seal in the original oil cooler housing has split which has resulted in the coolant mixing with the hydraulic oil.
Drained it all out as best as possible and refilled it then tried driving the car but hell no its having none of it and clutches are slipping until you get revs up to around 4k then they start to bite which is as good as a one legged bloke in an arse kicking competition lol
So eventually its come to this  thinking
GTR35 gearbox issues again 20160212_133348_zpsutumazn5
GTR35 gearbox issues again 20160212_185352_zpsvwb4nedz
GTR35 gearbox issues again 20160212_133411_zpstas4mnxs GTR35 gearbox issues again 20160216_200649_zpszn4tthmj
GTR35 gearbox issues again 20160216_200817_zpsr2t5epgg
GTR35 gearbox issues again 20160216_200710_zpstl15qolz
now got to strip the whole front section of gearbox down and remove the very expensive clutch basket housing the many clutches (2 per gear) Shocked
2GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 17th February 2016, 10:12 pm
Doesnt look like a job id want to attempt .... so do you think its just all the fluid and oil mixed in the clutch causing it to slip or is the strip down to gain access to the o-ring
3GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 17th February 2016, 10:46 pm
No the o ring can be easily got at as the cooler is bolted on front of box so already sorted that.
The issue now is the damage that could have been caused by the fluids mixing as the clutches are wet clutches similar to a motorbike and they don't take kindly to contaminated fluids or even the wrong fluid.
As well as that the solenoid packs around  12 in total which work in 2 directions so effectively around 24 movements half of those being electronic solenoids in the clutch pack area which will engage 2 clutches per gear.
These may not be working  as they should and if they malfunction could end up with them trying to engage 2 gears at one time which will lead to a not very nice outcome lol
So basically I need to strip the whole lot down to clean everything spotlessly and examine the drive plates to see if they are burnt where clutches have been slipping so not gonna be cheap as uprated new clutch pack starts at around £1800 if they are damaged which I suspect they are Neutral
4GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 18th February 2016, 8:46 am
Shit, bad luck Bob. Modern technology is good but so expensive is something goes wrong, especially a simple 5 bob 'o'ring.
GL with the strip and hope worst is not there and all is ok, just a bit of water stopping it all working.
5GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 18th February 2016, 9:46 am
Bandyleg
Bandyleg
WOW, that thing looks pretty!! Pretty always means expense, good luck and I hope you don't have to spend all the wedge.
6GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 18th February 2016, 10:04 am
cheers guys
will know more today as im going to strip the thing right down to try figure out what the issue is as I need the car fixed and out of my workshop.
Trouble is with these boxes, as well as being extremely complex everything you have to buy costs shed loads of money and an unknown used box can go for anything between 5-8k with them being around 16k new from Nissan stealership
If I had to take it in to get repaired then its £800+vat just to have the box removed that's before dis-assembly of the thing Shocked
ive heard of more than one case where people have had in excess of 22k bills to pay for repair and fitting of some modified parts
Kind of makes the Gtir seem like a very cheap little runabout lol
7GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 18th February 2016, 10:27 am
Fooking hell, must be keen to fork out some money.
Has anyone seen the new Japanese Performance Mag? there is a red R35 featured in it, so sexy.
8GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 18th February 2016, 10:31 am
Welling_AL
Welling_AL
Bloody hell - that's some serious wedge if you need such work done !
Luckily you're a man in the know - or at least getting to know....very intimately by the sounds of it !
Hope it all goes well Bob and no major parts need replacing !
Keep us updated.
9GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 22nd February 2016, 12:40 am
Well little update for those interested in the working or maybe demise of my gtr gearbox Laughing
Been finding it hard to find the time to work on this so came in today to start stripping it down bit by bit and gotta say I'm now getting to understand how this thing actually works and how the twin electro hydraulic clutch system works in relation to gear selection but basically each of the  solenoids in the clutch pack assembly is linked directly to its neighbouring solenoid in the main gear housing.
So ecu tells the solenoids that a shift has been made by driver and at that precise moment one clutch disengages the gear and other clutch is hydraulically depressed simultaneously which engages the next gear
so the really clever part with these boxes is actually the software written into the gearbox ecu.The timing has to be perfect in order not to crunch a gear which would be catastrophic given the power / torque and sheer speed in which these cars can select gear.
So I set about finding out what damage may have been caused by mixing the water with the fluid and that means a total strip down of the box (well at least the front and centre sections) as these both contain the electro magnets and solenoids which use very expensive hydraulic fluid in order that they are able to perform gear shifts at lightning fast speed so it's paramount that all solenoids are not hindered by shitty contaminated oil which can restrict the movement of clutch and gear select solenoids so a simple flushing of the system is nowhere near sufficient unless you want to end up with one big pile of smashed gear components What a Face
So from this
GTR35 gearbox issues again 20160212_185306_zpslrwhr6pq
It now looks like this Shocked
GTR35 gearbox issues again 20160210
GTR35 gearbox issues again 20160214
GTR35 gearbox issues again 20160215
That's just the front section which contains all the clutch basket and many drive plates, 4wd diff gear, hydraulics and solenoids that operate everything. I still need to totally strip down the solenoid packs and check their operation but the vlutch drive plates all look to be OK which is a good thing as they are very expensive.
Next will come the main gear section housing itself which needs to be split from the rear section that contains the rear diff etc
GTR35 gearbox issues again 2016-010
10GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 22nd February 2016, 8:31 am
FPSChris
FPSChris
Shocked
There's me thinking a pulsar gear box was complicated to strip.
Do you have a workshop manual for this tear down Bob?
It's really good to see you part documenting it.
11GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 22nd February 2016, 8:45 am
Fookin hell, If I did that the box would never be put back to together.
Next thing you'd see is me posting a thread selling GTR gearbox paperweights Laughing
12GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 22nd February 2016, 9:08 am
This was my dream car but scarred shitless of having one now. I can imagine my wife's face if I told her my garage bill was 22 grand
13GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd February 2016, 6:54 pm
ben15476
ben15476
All looks fairly clean though. Assume you have been cleaning the sludge off as you go right?
14GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd February 2016, 7:07 pm
@Bones wrote:This was my dream car but scarred shitless of having one now. I can imagine my wife's face if I told her my garage bill was 22 grand
buy any audi rs series car makes almost every super car repairs bills seem like small change if something goes wrong
15GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd February 2016, 8:10 pm
ben15476
ben15476
+1 to that!
16GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 24th February 2016, 2:08 am
@FPSChris wrote:Shocked
No book Chris, I truly am winging it Laughing
Trouble is with these boxes is its hard to get any info as its a closed shop with the big players such as svm and litchfield
So I'm trying to work Out exactly how it works as I dismember it and I'm learning fast..........I have to lol
Think I've found the issue now but won't commit myself until I've re-assembled it all and its hopefully all working. If that is the case then next time I pull one art I will feel confident in what I'm doing sometimes you just have to bite the bullet and chuck yourself in at the deepend
Far far from clean yet Ben, this thing needs to be spotless when it goes back together no dirt or contaminants whatsoever
17GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 24th February 2016, 6:26 am
That certainly the deep end .
Hope works spot on once assembled as give you confidence & right mind frame work on them again. Is a huge hassle with no workshop manual data or nissan training .
Don't think I will be stripping one lol, looks more stressful than spending time with her indoors :-S
18GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 24th February 2016, 10:26 am
Hopefully it works out ok for you mate
19GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 24th February 2016, 10:30 am
ben15476
ben15476
Stick the bits in the dishwasher then... Smile
20GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 26th February 2016, 12:46 am
Well bit more done this evening
Solenoid pack pulled apart, this has been the biggest challenge so far with lots of little springs, ball bearings, miniature filters and seals etc
Wasted an hour tonight as I dropped a tiny little spring and bearing and what a mission trying to find that fooker scratch
Tested all the solenoids out and all are working correctly. Next comes the clutches solenoid pack and solenoids which operate them and this is where I believe the problem lies.
Have to reassemble some of these things first though after thoroughly cleaning 'every single part' as I've ran out of worktop space to put everything and that's 14 ft long lol
Here's some more pics
GTR35 gearbox issues again 20160217[/url]
GTR35 gearbox issues again 20160218
GTR35 gearbox issues again 20160219
GTR35 gearbox issues again 20160221
GTR35 gearbox issues again 20160222
GTR35 gearbox issues again 20160223
21GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 26th February 2016, 2:52 am
Wow! At nearly 3.00am you should be getting some sleep as we all know that's when little errors creep in and you don't want that happening.
22GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 22nd August 2016, 11:00 pm
Well its been a few months as been so busy wirking on other cars that not had time to sort my own out but a few more late nights recently and 7 day weeks and finally its all back together and ready to go in after the rebuild.
GTR35 gearbox issues again 20160811
So im praying she all works ok after programming the tcm to sync with main ecu
So will find out this week  at some point if it works or uf i have to take a hammer to it lol
One thing i do know is that this assembly is fookin heavy, killed my back lugging this lot around but il take that if it all works
23GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd August 2016, 5:56 pm
Well done Bob, really hope it works after all those late nights. you the man
Did look a hell of a challenge with all those bits on the work bench.
24GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd August 2016, 7:10 pm
mightydquinn
mightydquinn
Looks good on the outside! Good luck! Smile
25GTR35 gearbox issues again Empty Re: GTR35 gearbox issues again on 23rd August 2016, 7:18 pm
You are one crazy fucker Bob lol
Fareplay to you for getting stuck in tho.
Its amazing looking at all those pictures of parts that you know where everything goes!
Here's me moaning about fucking about with my gtir..
Hopefully its all good once back in.
