Gtir Motorsport club » General Discusion » Gtir related Discussion » ACL vs standard crank bearings
1 ACL vs standard crank bearings on 20th February 2016, 10:04 pm
Hi,
So after a couple of months decorating the whole house I'm allowed back working on the car Laughing
Is it worth getting the ACL Bearings over standard? I want to get the engine built back up before the baby arrives!
Also other than Nissan where's the best place to get new piston rings from?
Gaz
2 Re: ACL vs standard crank bearings on 21st February 2016, 1:23 am
If you know the bearing grade Gaz then I would personally go for the Nissan bearings, 5 different grades in all I think.
Companies such as Hepolite and a fair few others do the rings think there anything between £70-100 a set depending  on where you get them
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
3 Re: ACL vs standard crank bearings on 21st February 2016, 9:52 am
ADSgtir
I would have a word with mahle and see if they do bearing sets for the pulsar , the Motorsport range are mighty fine bearings and indium coated , running over the stock rpm , requires bearings rated for the extra rpm : mahle Motorsport
You will never know until you ask , but they are keen to expand their range and costs are not that much over standard bearings
Paul Grosvenor
MAHLE Aftermarket Ltd.
National Sales Manager (Engine Components)
Springvale Avenue, Springvale Business Park, Bilston WV14 0QL West Midlands, Great Britain
Phone: +44 (0) 1902 357-123, Fax: +44 (0) 1902 357-113
4 Re: ACL vs standard crank bearings on 21st February 2016, 11:33 am
Would be good have another option as not great fan of acl bearings as clearances only able set finely if do a grind & polish to match measured fitted acl undersize shells in block .
For a standard crank in good shape then nissan shells are best option unless building with larger clearances .
5 Re: ACL vs standard crank bearings on 21st February 2016, 11:50 am
Cheers guys, will go for standard ones then, I priced them a month or so ago and not bad really.
On a different note, in the past ive used Loctite SI5660 liquid gasket for chain covers, sump etc or is it worth me going for the more expensive genuine Nissan sealant? Think it was £30 or there abouts when I priced it.
Gaz
6 Re: ACL vs standard crank bearings on 21st February 2016, 11:57 am
That loctite or similar will be fine & much cheaper.
How big is nissan sealant tube !?
7 Re: ACL vs standard crank bearings on 21st February 2016, 12:01 pm
Prob same as the loctite maybe a little bigger, I did get one years ago when I changed the rocker gasket, remember it being fairly big tube.  Might have changed now!
Liquid Gasket KP510-00150- alt no: KP710-00150- KE10050000 £28.88 Available
