Gtir Motorsport club » General Discusion » Gtir related Discussion » Dyno graphs please
Dyno graphs please
1 Dyno graphs please on 21st February 2016, 1:40 am
Bit of a strange request this one
But could anyone who had a Dyno printout for their car (ideally with boost and afr showing) put the graphs up please
If you could also state whether mapped, generic chipped ecu or just boost / fuelling setup on stock, also ecu type would be appreciated.
Last of all.......Turbo it's running, maf, injector size ex system, intercooler type and whether she's running cams or stock
I'm looking at doing a kind of gtir portfolio so putting cars into various brackets so I can take measured readings at given levels with certain cars that have similar modifications and in similar states of tune
Won't tell you yet what we're up to but there's a very good reason in doing the above which could benefit owners in the long run so dig them out and put them up please guys n gals thumbsup
                                GTI-R-US.CO.UK
                                            'In association with'
                                          'Services provided'
2 Re: Dyno graphs please on 21st February 2016, 11:23 am
Here's mine again.
All standard bits with UK Sunny ECU.
3 Re: Dyno graphs please on 21st February 2016, 12:43 pm
Standard Engine & err Clutch Laughing  Walbro pump, FMIC, Scorpion Exhaust, HKS Filter, HKS piggy back PFC F-Con Fuel Controller, Apexi Boost controller running 1.3bar, Was running this setup for 7 - 8 years without a problem, turbos got a bit of play and the clutch is kinda smooth now! Never been mapped.
Flywheel HP
Wheel HP
Gaz
4 Re: Dyno graphs please on 22nd February 2016, 10:43 am
Welling_AL
Here you go Bob,
Standard: Engine / Turbo / ECU / Injectors
Uprated: Fuel Pump Walbro / FMIC / Bogdan Elbow / Full Goose Exhaust / Blitz SUS Filter / Dawes Device Ball & Spring (1.2 bar boost)
Never been officially set-up - fueling ok'd at various rolling road days - last one print out below
AL.
5 Re: Dyno graphs please on 22nd February 2016, 5:36 pm
Spark plug spike
Standard ECU, standard injectors, Walbro fuel pump, standard MAF, 360 degree bearing standard turbo, 2.75" EBay turbo elbow, standard top mount intercooler, standard cams, full decat mongoose exhaust, Apexi air filter,
Dawes device manual boost controller, 1.1 bar boost, fuelling and ignition adjusted using the old style Apexi SAFC and SITC.
6 Re: Dyno graphs please on 22nd February 2016, 6:17 pm
Party Petes car
Nistune ecu
GT2871R
z32
700cc injectors
AM performance elbow
Goose exhaust
HKS filter
7 Re: Dyno graphs please on 23rd February 2016, 1:07 pm
Kate&tim
Forged 2.0
Hks 264 cams
Hks 3037
Top mounted manifold with screamer
Big cooler
680cc injectors
Avcr and afc neo running it
Boost 1.2 dropping to 1.1
8 Re: Dyno graphs please on 23rd February 2016, 7:01 pm
this is one from one of my cars ive another one from the following year but cant find it
spec is
660cc injectors
z32 maf
t2860 turbo with motorsport spec bearings and 34mm restricter
forged engine
forge intercooler
apexi ecu
running 1.3 bar
9 Re: Dyno graphs please on 24th February 2016, 11:02 pm
GT2871R .64ar at 0.8bar
AM performance elbow + downpipe
5 Zigen exhaust (2,75 in I believe)
Walbro fuel pump
Standard management (ecu injectors maf)
Blitz air filter
