Gtir Motorsport club » Tech room » Help and Advice » injector rebuild
injector rebuild
1 injector rebuild on 21st February 2016, 12:09 pm
Ok I've taken my injectors out because one of the ones rings was leaking but I've got other bits in the kit as shown hopefully in the picture now I think there filters should I change them and do the go in the top? If so how do I get them out? Same as what look like caps for the bottom, should I change and if so how
2 Re: injector rebuild on 21st February 2016, 1:57 pm
filters can be pulled out with self tapping screw & mole grips, tap new ones in gently with hard nylon or copper hammer ideally. assume others are bottom pintle caps which helps retain the lower o-ring, they can be pushed/tapped on .
3 Re: injector rebuild on 21st February 2016, 4:31 pm
Thanks it worked a treat
