Gtir Motorsport club » General Discusion » Gtir related Discussion » High idle cure
High idle cure
1 High idle cure on 11th March 2016, 10:29 pm
Been trying to get round to this for years, well since I had the throttle bodies off about 5 years ago and noticed the problem.
So in many cases vacuum leaks are the cause but a common problem is the factory seal on the butterflies wearing to the point this happens when held up to light:
My IACV was screwed all the way in but still idled at 2000rpm, each butterfly was the same, so a lot of air be dragged through..
Today was the day to apply Molykote 321
Sprayed it into a aerosol lid and brushed round the edges, left it for 12hrs or so and gently opened them, causing the dry lubricant to crack, close the butterfly to a perfect seal
Held up to the light, and no halo, sweet!  Unfortunetly I won't be trying them for some time but very confident it'll work!!
Hopefully this info is of use to others..
Gaz
2 Re: High idle cure on 12th March 2016, 11:27 am
grim_d
Surely there is supposed to be a bit of a gap else it will be acting as a choke (IACV aside), I don't think I've seen a TB that seals perfectly?
I am not saying they do not wear and become too big however.  Wonder if new butterfly plates are available?
Pretty inventive idea but I would be very concerned about the molykote becoming brittle with vibration and entering the engine. Little chunks of it hitting the turbine blades can't be good.
We have that Molykote 321 at work however ive never used it or even know what it's used for, maybe ill investigate tonight. Laughing
3 Re: High idle cure on 12th March 2016, 1:26 pm
I've read about this on various other forums, Mitsubishi Subaru and various American sites, mainly from people cleaning the butterfly plates, and rubbing the original factory sealant off thinking it was oil Laughing then low and behold their idle is sky high.. The product that's been used on all these sites is Molykote 321.. Can't remember which forum it was said that its pretty much the same as factory seal.
Bits of my original stuff had already worn off.
Google Molykote 321 throttle body, loads of info comes up.
Gaz
