Gtir Motorsport club » General Discusion » Gtir related Discussion » boost controller
boost controller
1 boost controller on Mon Mar 14, 2016 5:53 am
luke s
I'm running a profec b 2 I'm struggling getting a good stable boost I'm suffering spikes I've read every setup but no joy
IS ANYONE RUNNING THIS EBC?
I know it's not ghetto done thing but I was thinking of getting a bleed valve setting it up then job done
2 Re: boost controller on Mon Mar 14, 2016 8:26 am
I can't help with the settings, but know they can be difficult to get right. A lot of people run them fine so hopefully you can get some assistance here Smile
3 Re: boost controller on Mon Mar 14, 2016 5:20 pm
Well if you get a dawes device or simular you can then quickly rule out any issues with you electronic jobbie. Try a dawes device in the same general vac pipe setup. If it holds boost fine you know your solenoid may be duff or something else along those lines.
4 Re: boost controller on Mon Mar 14, 2016 5:40 pm
luke s
That the lines I was thinking,I had the solenoid tested and the main unit repaired last year do doubt it's that, but once it's set up there won't be a need to adjust it all the time anyway, what's the signs of a weak actuator spring on the waste gate?
5 Re: boost controller on Tue Mar 15, 2016 12:22 am
hagger
I have a profec B spec 2. I found this was a good set up on a standard turbo.
gain 15%
set gain 0.60
set 50%
I found this was a good all round set up and made about 0.97 bar of boost.
6 Re: boost controller on Sat Mar 19, 2016 6:20 am
luke s
OK thank you are you on WhatsApp? I'll have to try pop over now mines not far runin and your not far away either
7 Re: boost controller on Sat Mar 19, 2016 10:50 pm
hagger
No problem. Ive not finished my car yet but hopefully in the next 2 weeks.When mine is finished we can can meet up for a chin wag ;-)
8 Re: boost controller on Sun Mar 20, 2016 3:22 am
luke s
Sounds great to to me bud I'm moving house in a couple of weeks but drop me a message with your number and we'll have to meet up
