Gtir Motorsport club » active members adverts » Parts Wanted » Wanted O/S ABS sensor
1Wanted O/S ABS sensor Empty Wanted O/S ABS sensor on 21st March 2016, 6:30 pm
Can anyone supply an O/S ABS sensor?
My ABS wiring has been pulled right out the plastic sensor cap.
Maybe it's repairable but i don't have the skills to do it.
If i cant get a replacement would anyone be willing to repair mine? Ill make it worth your while.  Very Happy
Thanks
Wanted O/S ABS sensor Image10
2Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 25th March 2016, 11:14 pm
These things are rarer then rocking horse shit!
Ive come across these new ones but they're almost a grand
affraid
http://www.mister-auto.ie/en/abs-sensor/nissan-sunny-mk-iii-hatchback-n14-2-0-i-16v-143hp_v10645_g412.html
3Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 26th March 2016, 11:15 am
If no one else is offering I'd be happy to have a look. No promises... Shocked
Have you still got my address?
4Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 26th March 2016, 3:12 pm
Hi John,
If you can help me (again) ill be over the moon!
you the man
Please could you PM your address?
Really appreciate your help.
Cheers
Very Happy  Very Happy
5Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 26th March 2016, 7:02 pm
I expect it possible find other sensor that fits hubs then graft on cable or adjust cable & graft on plug to make up your own.
the original nissan ones only covered couple car models besides the R but expect other nissan sensor heads are compatible & aftermarket brands start around £20 so would be worth looking into for those needing abs cables .
I'm lucky I don't have abs :-)
6Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 5:07 pm
Getting there.
Just got to decide what to seal it up with..
Wanted O/S ABS sensor 20160405_172214_zpslksdse87
7Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 6:41 pm
Not the neatest, but it should stay together for a few miles... Shocked
Wanted O/S ABS sensor 20160405_185205_zpsstxh8iu0
8Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 7:24 pm
Hey John, that's amazing, youve done a top job.
I really didnt think this was salvageable!
Ive PM'd you a message too
Thanks
Smile Smile Smile
9Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 7:31 pm
Well done johnboy hope all is well long time no see
10Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 8:42 pm
Could you have sealed it up with aroldite ???
11Wanted O/S ABS sensor Empty Re: Wanted O/S ABS sensor on 5th April 2016, 9:41 pm
Was going to use araldite but decided it wouldn't give any flexing at the joint. Used hot melt glue in the end, with heatshrink and self sealing rubber tape. Should be OK as long as doesn't get too hot. Shocked
Johnny - I'm sure I'll see you at something sooner or later.??
