Gtir Motorsport club » Tech room » Help and Advice » abs sensors
abs sensors
1 abs sensors on 23rd March 2016, 4:08 pm
Does anyone know wether the front abs sensors are handed?
Are they left and right or can you use them on any side?
Thanks.
2 Re: abs sensors on 23rd March 2016, 4:11 pm
They are handed. It is possible to fit on the wrong side but you have to make/modify mountings.
3 Re: abs sensors on 23rd March 2016, 4:32 pm
Okay thanks mate
4 Re: abs sensors on 23rd March 2016, 8:12 pm
The plugs are different left/right from memory?
5 Re: abs sensors on 23rd March 2016, 9:02 pm
Yes they are, but you can cut the 'key' off and then they'll plug in either side..
I know all this as I did it a couple of years ago. When the sensor goes in to the hub it has to be rotated to align properly with the abs ring on the driveshaft. This means the bolt hole doesn't line up so have to make up a bracket to keep it in place. Once it's all in it works fine. Smile
6 Re: abs sensors on 23rd March 2016, 9:38 pm
Oh really?? I never knew this, I've just replaced the plug and bolted it up. Haven't driven the car so never knew, thanks for that
7 Re: abs sensors on 23rd March 2016, 10:24 pm
Some great info there mate thanks. Rep given Wink
8 Re: abs sensors on 23rd March 2016, 11:09 pm
@gtir_woody wrote:Oh really?? I never knew this, I've just replaced the plug and bolted it up. Haven't driven the car so never knew, thanks for that
Yes, if you look at the actual pickup head it's rectangular and that has to be the right way round relative to the abs ring or you won't get much signal. Mine didn't work at all till I turned it.
Will try and find a picture tomorrow.
9 Re: abs sensors on 23rd March 2016, 11:28 pm
Good to know, never even thought to look obviously that's why the plugs are different for each side.
