Gtir Motorsport club » General Discusion » Gtir related Discussion » Width
Width
1 Width on 23rd March 2016, 6:40 pm
Are pulsars wider on the front track than the back? If so does any one know by how much?
And also when fitting spacers how many mm ideally should they be wider front/rear?
2 Re: Width on 23rd March 2016, 6:49 pm
I was always led to believe its best to go 10mm more on the back .... although i could be talking b*llocks Laughing
3 Re: Width on 23rd March 2016, 7:03 pm
Do you know if they are wider at the front or the back standard?
4 Re: Width on 23rd March 2016, 8:11 pm
I could be wrong but the front is 25mm wider
5 Re: Width on 23rd March 2016, 8:33 pm
This is getting confusing now Razz I'll be running spacers but want to know if best to be slightly wider front or back
6 Re: Width on 23rd March 2016, 9:08 pm
I thought Run half on front compaired to rear which goes with what Leighton says helps with under steer
7 Re: Width on 23rd March 2016, 9:40 pm
I'm running 10mm on the rear, haven't driven it though.
8 Re: Width on 23rd March 2016, 9:48 pm
I think that it always looks like the rear wheels sit in further than the fronts ...
9 Re: Width on 23rd March 2016, 9:53 pm
I don't know about other cars but standard 25mm track difference seems a lot? And you're right, just visually the rear wheels sit further in. Nissan must have done this for a reason at the time.
10 Re: Width on 24th March 2016, 10:21 am
Bandyleg
nothingtoadd
Just want to follow it
11 Re: Width on 24th March 2016, 10:31 am
Moss Ali
One of the criticisms of the Hurican is that the front end is wider than the rear and it makes the car understeer. Lambo done it to make the car more road friendly and safe. Since Sunnys were mostly going to be driven by old grannies and new drivers, that's probably why they done the same here and then the same design was carried over to the R for some reason (probably Group A homologation rules)
