Gtir Motorsport club » Tech room » Ecu related section » Z32 MAF
Z32 MAF
1Z32 MAF Empty Z32 MAF on 14th August 2012, 10:51 pm
Drift God
Drift God
At what point should you consider changing the standard MAF to a Z32?
2Z32 MAF Empty Re: Z32 MAF on 15th August 2012, 12:45 pm
if your going over 80% of stock afm then its time to change it to aftermarket
that would be circa 330-335bhp
3Z32 MAF Empty Re: Z32 MAF on 15th August 2012, 1:03 pm
Drift God
Drift God
gtirus wrote:if your going over 80% of stock afm then its time to change it to aftermarket
Cheers Bob think im ok for now then, will see when i get it on the rollers when i sort out the paint and brake upgrade and all that fuel regulator.
you have any gauges that will do the job? also can you check my pm and give me a price on them bits, thanks again Very Happy
4Z32 MAF Empty Re: Z32 MAF on 15th August 2012, 2:43 pm
Stock afm is normally 100% at 340ish.......just get a z32 and be done with it
5Z32 MAF Empty Re: Z32 MAF on 15th August 2012, 8:06 pm
Drift God
Drift God
On the Ball today Dan, cheers cheers
6Z32 MAF Empty Re: Z32 MAF on 12th July 2013, 1:51 pm
Heydude
I am new own of GTi R, my R is bone stock. Does change the Z32 MAF will better for the car?
http://www.ttlas.com
7Z32 MAF Empty Re: Z32 MAF on 12th July 2013, 2:32 pm
If its completely stock it should be fine with the oe maf
8Z32 MAF Empty Re: Z32 MAF on 12th July 2013, 3:03 pm
yes as above
you only need to change the maf to a larger one if the cars running over circa 335bhp
