Gtir Motorsport club » Tech room » Help and Advice » hubs
hubs
1 hubs on 1st April 2016, 7:10 am
How do I split the rear hubs so I can get the dust covers off please?
2 Re: hubs on 1st April 2016, 9:44 am
Hub nut .... bottom bolt holding the hub dont forget to remove caliper just hang it up off the spring with a couple of cable ties ...... then two bolts that hold the suspension strut that will remove the hole hub ....
3 Re: hubs on 1st April 2016, 11:38 am
Ye I've got the hub off and totally stripped down but I need to separate the hub itself to get the break disc dust core off.basicall do I need to get the wheel bearing out or something cos I can't see how to part it
4 Re: hubs on 1st April 2016, 11:59 am
I think you'll more than likely have to replace the wheel bearings mate
5 Re: hubs on 1st April 2016, 5:36 pm
Get them off for to get rid or replace or ?
6 Re: hubs on 1st April 2016, 6:43 pm
press out, drive out the hub spindle (universal bearing/hub removal/install kit are handy). once removed you can then get shield off the hub knuckle ...
7 Re: hubs on 2nd April 2016, 9:35 pm
Just to blast and paint
8 Re: hubs on 2nd April 2016, 10:02 pm
I used one of these kits to do all 4 on mine, using a air gun makes it easier with the tool:
http://www.ebay.co.uk/itm/Front-Wheel-Hub-Drive-Bearing-Removal-And-Installation-Car-Repair-Tool-Kit-Set-/221851897344?hash=item33a7674e00:g:vNIAAOSwLVZVzGHo
9 Re: hubs on 3rd April 2016, 6:17 pm
I'm with the welsh wizard on this.
I got a set similar to that, works great, used it on mitsi subarus & the old nissan, makes job easy & far better for bearing cartridges .
10 Re: hubs on 13th April 2016, 11:29 am
The right size socket on a half inch shaft knocks the hub out really easy. Could do bearing with my eyes shut now. Thanks
