Gtir Motorsport club » Tech room » Help and Advice » Car wont idle with maf connected
1 Car wont idle with maf connected on 1st April 2016, 6:42 pm
Lazzie90
Hi there
First of all thanks bob for a quick delivery.
So my pulsar which now has been checked through multiple times after the new wire harness was connected and all the megasquirt bs removed.
Original ecu in use, only thing is a bigger turbo, fmic, downpipe etc being changed.
Car starts fine but doesnt idle with maf connected, it misfires and runs poorly but with full throttle it runs pretty ok but but.. I dont know what to do.. Theres also a afr wideband in use..
Video here: with maf connected and throttle pumping and then mid video i disconnect the maf.
https://youtu.be/JDMBAS_EGsU
Im about this close to just sell it in parts since ive invested shit tons of money into this garbage.
Thanks for your time.
Br. Stefan
2 Re: Car wont idle with maf connected on 1st April 2016, 7:29 pm
Have you cleared the fault codes?
3 Re: Car wont idle with maf connected on 1st April 2016, 7:49 pm
Lazzie90
@Stu wrote:Have you cleared the fault codes?
Actually not before installing the new maf no..
Gna try that tomorrow if there is any.. Last time i ran it on the roaf it gave the maf fault code.
Br.
Stefan
4 Re: Car wont idle with maf connected on 1st April 2016, 8:07 pm
Try that first and give it a go. Might just be old codes making it run shit!
5 Re: Car wont idle with maf connected on 2nd April 2016, 7:45 am
Are you able to plug the car in and read the ecu?
6 Re: Car wont idle with maf connected on 2nd April 2016, 10:00 am
Not similar to you stu the shape of intake ?
7 Re: Car wont idle with maf connected on 2nd April 2016, 10:01 am
8 Re: Car wont idle with maf connected on 2nd April 2016, 10:01 am
9 Re: Car wont idle with maf connected on 2nd April 2016, 10:50 am
No i don't think so Johnny. Symptoms are different.
Mine just idles up and down and stalls.
Where as this one sounds rough and you have to rev through it.
This one sounds like it's getting the wrong signal from the afm and maybe getting the wrong air fuel mixture as a result?
10 Re: Car wont idle with maf connected on 2nd April 2016, 12:03 pm
Lazzie90
@Stu wrote:No i don't think so Johnny. Symptoms are different.
So i tries resetting the codes, and now it gives 55 that is no faults if im correct.
But still stalls on idle and misfires abit, going to upload a better video aswell.
And even on the bad idling it doesnt give any faults.
Br. Stefan
11 Re: Car wont idle with maf connected on 2nd April 2016, 12:24 pm
Lazzie90
Heres a new video after fault codes are removed.
https://youtu.be/HmbL5UjPRCs
12 Re: Car wont idle with maf connected on 2nd April 2016, 12:55 pm
Have you cleaned the plugs? When its not running well they can quickly fowl up and it wont run at all. Also might be lambda sensor not working as mine runs like a sack of shit without it and also if left and plugs get fowled they need to be cleaned up.
Does seem like a really odd intake setup as well as I notice your breathers are none existant and you just have a filter on the end.
Maybe try re soldering/earthing your afm connector and checking its in correctly
13 Re: Car wont idle with maf connected on 2nd April 2016, 1:05 pm
@johnny gtir wrote:Not similar to you stu the shape of intake ?
Looking at that last video i think you are correct mate.
Try putting a piece of woman's tights/stocking between the afm and induction pipe.
I had this issue and it was turbulence because the intake pipe isnt correct shape..
14 Re: Car wont idle with maf connected on 2nd April 2016, 3:49 pm
Lazzie90
Ok stupid question but, I put the womens stockings betwewn the filter and the maf.. Not sure if that was correctly put, or should it be after the maf?
With the way i did it, it atleast took a turn for the worse Very Happy
Oh man... This car has been a struggle but thank you guys for the tips! And your time.
15 Re: Car wont idle with maf connected on 2nd April 2016, 4:44 pm
Sounds like its misfiring ..... have you checked the dizzy and rotor arm grub screw ????
16 Re: Car wont idle with maf connected on 2nd April 2016, 5:27 pm
Lazzie90
@nomad wrote:Sounds like its misfiring ..... have you checked the dizzy and rotor arm  grub screw ????
Hey! What is a dizzy? Very Happy Ive changed the whole distributor system to a new one atleast.
And i ran out of gas it seems so im going for some beer now and head back out tomorrow..
17 Re: Car wont idle with maf connected on 2nd April 2016, 6:09 pm
Gtirchris
If the sensor in the maf is dirty it will give conflicting signals, which will make it run like a sack of shit, try cleaning it with contact cleaner or a little bit of brake cleaner, then retry it mate
18 Re: Car wont idle with maf connected on 2nd April 2016, 6:16 pm
You put it the wrong side.
Put it between the afm and the induction pipe.so the air goes through the afm first and then through the stocking...
19 Re: Car wont idle with maf connected on 5th April 2016, 11:34 pm
Sounds to me as though you have a leak somewhere on maybe throttle bodies or pipes incorrectly plumbed to plenum or carbon canister.
This can cause issues if the canister over pressurises or if diaphragm is split in canister itself which then allows carbon deposits to get sucked out via vacuum system.
Best bet is try and dis connect the canister and block vacuum pipes from plenum then see if that makes difference
20 Re: Car wont idle with maf connected on 6th April 2016, 8:11 am
Lazzie90
Thank you all for the comments !
I will take a look again now that i have time to visit it.. my daughter got sick so had to leave it again for some time but but..
I soon have double or triple of all parts for the car and the wish was to have it on the road this summer but seems it will be another year in the garage.
Br
Stefan
21 Re: Car wont idle with maf connected on 12th April 2016, 3:51 pm
Lazzie90
Put the stockings after the maf and runs alot worse.
Missfires like crazy and wont go over 2k rpm.
All pipes are sealed aswell so its weird
22 Re: Car wont idle with maf connected on 12th April 2016, 3:57 pm
Maybe you need to earth the afm?
Have you cleared the codes now?
23 Re: Car wont idle with maf connected on 12th April 2016, 4:26 pm
Lazzie90
Codes are cleared yes.
Seems like the plugs died tho.. Since it doesnt start anymore.
