Gtir Motorsport club » Tech room » Help and Advice » Washer motor replacement and heater problem
1 Washer motor replacement and heater problem on 3rd April 2016, 6:51 pm
Have I asked before (possibly) anyone know if there are straight replacement motors to fit both bottle and original plugs as front and rear different plugs for washer jets. And one I have read lots but never had the problem and can not remember heaters blow hot all the time and fan only works on 2and 3 not working on 1 or auto
That will be the heater card have a word with stu as think he was doing a fix and post return with them .....
For washer motors >
they same pumps as on pre 2000 almera, xtrail, sunny, sentra, 100nx, maxima etc
You can find them in salvage yards or buy pattern ones
front has 2 spades l -   . nissan P/N 2892050Y00
rear has 2 spades l l    . nissan P/N 2892050Y10
you can use 2 fronts if change connector
fronts are easy find & cheap>
http://www.ebay.co.uk/itm/FOR-NISSAN-ALMERA-1995-1998-FRONT-ONE-OUTLET-WINDOW-WASHER-FLUID-PUMP-/171875191123?hash=item28048f4953:g:F2gAAOSwLVZV1D-T
rear with correct pin layout ( l l ) not so easy or cheap but think blueprint do one ADN10316
Most people just use the front style & convert plug as they so cheap & available anywhere.
don't even need cut & solder as you just remove the 2 female spades from plug block (prong finger holds them in) & refit into a salvaged front plug block .
Ideal on both thanks lads. Might as well add it here but might clean thread up for others to get washer answer.
Hubs take it you can get none abs hubs as doing away with it on my car and just thought I might source Hubs without the sensor hole
^ you certainly can as they done a knuckle for non abs & another for abs .
Spot on Mr B rep your way as your great for this forum and always straight there with sound advice.
Happy to help mr johnny .
Animaldaz
As above I replaced both my washer pumps recently with blueprint ones sourced through my local motor factors. Both a perfect fit and had the correct connectors, about £15 each .
^ yes
I believe front washer blueprint P/N is ADN10315 .
Rear as mentioned before ADN10316
A proper decent motor factors will be able sort these no problem.
If you want be cheap/free/recycle go breaker yard as same pump is on a load of nissans, izuzu & honda.
