Gtir Motorsport club » Tech room » Help and Advice » Washer Bottel Relocation
1 Washer Bottel Relocation on 24th April 2016, 4:31 pm
joetheeskimo
HI All
Does anyone know the colours of the wires for windscreen washer motor around the steering colum. I got an after market washer bottle and its now in the boot but need to plum it in, so rather than go through the firewall i just want to plum into the steering colum area.
thanks
2 Re: Washer Bottel Relocation on 24th April 2016, 6:35 pm
Can only be the couple coming of the stalk mate. Do you own a multi meter ? You running a pipe or tee into rear one
3 Re: Washer Bottel Relocation on 24th April 2016, 6:47 pm
joetheeskimo
@johnny gtir wrote:Can only be the couple coming of the stalk mate. Do you own a multi meter ? You running a pipe or tee into rear one
Ive teed into the rear one.
Only asking just to save me the hassel of buzzing them out. I will buzz them out sometime this week. Only need the +VE as the 0V i will just tie to GND
4 Re: Washer Bottel Relocation on 24th April 2016, 8:13 pm
Thank god no ones answered fiddly little fooker but been outside tested and worked it out for you bottom left plug as you sit in drivers seat under wiper stalk plug has two rows bottom very left is black earth. Very bottom right pin to a pink wire that's the one you need
5 Re: Washer Bottel Relocation on 24th April 2016, 8:47 pm
Nice one johnny ive gave you a rep for going out your way to help Wink
6 Re: Washer Bottel Relocation on 24th April 2016, 8:51 pm
Thanks mate was not massive job but went out and was fiddly but like to help where I can I getting good with wiring on these after dash etc should come in useful older the cars get
7 Re: Washer Bottel Relocation on 25th April 2016, 10:08 am
joetheeskimo
@johnny gtir wrote:Thank god no ones answered fiddly little fooker but been outside tested and worked it out for you bottom left plug as you sit in drivers seat under wiper stalk plug has two rows bottom very left is black earth. Very bottom right pin to a pink wire that's the one you need
Spot on dude, thank you for doing this you didnt have too but i appreciate it
8 Re: Washer Bottel Relocation on 25th April 2016, 5:09 pm
No problem. When I write stuff it can come over wrong I wrote about the multimeter as I am a sparky and a lot of people believe it or not don't know how to test things. But it could of read like I was saying use a multimeter u lazy twat lol. So thought I would pop out n check. Anyone doing a track can use existing pipe from front to rear swap that and I jumped into the heated screen wire but like I say that's track prep cars where rear screen demister and rear wiper not getting used
