Gtir Motorsport club » General Discusion » Gtir related Discussion » clutch problem
clutch problem
1 clutch problem on 24th April 2016, 9:17 pm
Moss Ali
I was stuck in traffic on the way back from Japfest and pressed the clutch to put it in first and suddenly heard a loud crack. Then the clutch went low down and I didn't need to press much anymore before it reached the floor. It also didn't spring back up except only a little, though it still gave resistance when depressed and the car wouldn't go in gear without me forcing it in. Also noticed the clutch pedal vibrating on the M1 at higher speeds eventhough it has the clutch support bracket. What could it be?
2 Re: clutch problem on 24th April 2016, 9:49 pm
Clutch fork snapped?
3 Re: clutch problem on 24th April 2016, 10:10 pm
Moss Ali
Yeh sounds about right . Most probably a partial break
4 Re: clutch problem on 24th April 2016, 10:13 pm
Type of clutch ? Power your running which normally indicates torque figure age/mileage of clutch. Start by pulling the rubber boot off top of box look in see if the clutch fork looks ok or bent weather pivot balls broke through if not box off and go from there
5 Re: clutch problem on 24th April 2016, 10:48 pm
Moss Ali
Around 310-20 hp with an exedy stage 1 organic clutch . And it's supposed to have had a reinforced fork fitted too lol. Maybe not .will have to see
