Gtir Motorsport club » Gallery » Members gti-r's » My old girl
My old girl
1My old girl Empty My old girl on 28th April 2016, 1:51 pm
TrueRebel
TrueRebel
Just gave her a quick clean. She was a bit green.
My old girl Gtir1310
My old girl Gtir2310
My old girl Gtir3310
My old girl Gtir4310
My old girl Gtir6310
2My old girl Empty Re: My old girl on 28th April 2016, 1:54 pm
Bandyleg
Bandyleg
Looking good man Smile what sthe rubber bit accross the front slam pan for ?
3My old girl Empty Re: My old girl on 28th April 2016, 2:18 pm
TrueRebel
TrueRebel
I had to remove the slam panel to fit the intercooler as it wouldnt fit with it in place. So I made a new piece (its metal just looks that way in the pic) to tidy it up a bit and hide the loom until I make a new one for when it gets painted.
4My old girl Empty Re: My old girl on 28th April 2016, 8:13 pm
Looks like it has a fair bit of work put into it mate, bet you are happy to get it moving again Smile
5My old girl Empty Re: My old girl on 28th April 2016, 8:48 pm
kevmc76
kevmc76
you have been busy great work
6My old girl Empty Re: My old girl on 28th April 2016, 9:01 pm
Looks intresting .... whars the spec ????
7My old girl Empty Re: My old girl on 29th April 2016, 9:26 am
TrueRebel
TrueRebel
Thanks guys. The spec is as follows..
Piper 278 deg cams with vernier pulleys
ARP head studs
ARP main studs
ARP rod bolts
ACL race series main/thrust bearings
ACL race series big end bearings
Wossner pistons
Fully ballanced bottom end
GT2871R turbo
Custom exhaust manifold
TiAL MV-S waste gate
Custom elbow/down pipe
Mongoose exhaust
AP racing clutch
HKS BOV
Adjustable FPR
Walbro fuel pump
PACE RS 500 intercooler (modified to fit)
Alloy cosworth radiator (modified to fit)
Nitrous Oxide kit (100bhp)
I originally built it to be drivable and pull hard and spool fast from bends etc and not for drag times. Put the nitrous on just in case you meet something fast. As I have had the car for 15 years now a lot of the mods were done when kits for it were readily available.
My coilovers have had it so need to invest in a new set and also upgrade the brakes as they are pants. Also need to fit a new management system and run it at around 380bhp (without nitrous). Very Happy
Are any of you guys running BC coilovers? If so how are you getting on with them?
8My old girl Empty Re: My old girl on 29th April 2016, 9:50 am
Great specs mate, cant wait to hear more about your car.
I have bc's on my R and used them for 3 years on my daily driver which was a bmw e36. Really happy with them and no complaints, I think they are a great coilover for the price.
In regards to the nitrous Laughing
My old girl 33979097
9My old girl Empty Re: My old girl on 29th April 2016, 10:20 am
TrueRebel
TrueRebel
Haha cheers mate. Laughing
Brilliant, that clears that up. I will get a set of those then. I was thinking about going for the softer spring rate as my last set are too hard and used to handle better with the std shocks. What spring rates are you running and how is it in the road? Pot holes everywhere near me. Sad
10My old girl Empty Re: My old girl on 29th April 2016, 10:45 am
I haven't actually driven my car with the standard BC spring rates for the R, but some of the other lads here will be able to comment that you far better off ordering them with softer rates. I know there was a thread on it here, but I remember bob (GTI-R US) recommending the best spring rate to me.
11My old girl Empty Re: My old girl on 29th April 2016, 12:24 pm
TrueRebel
TrueRebel
Ok brilliant. I will see what info can find on here. Thank you Very Happy
12My old girl Empty Re: My old girl on 29th April 2016, 1:21 pm
Speak to bob as he is a bc stockist and will get them cheaper for you ...
13My old girl Empty Re: My old girl on 29th April 2016, 1:59 pm
TrueRebel
TrueRebel
Will do. Thank you. thumbsup
14My old girl Empty Re: My old girl on 29th April 2016, 2:30 pm
Interesting setup definately different to what I have seen before! Any reason for the intercooler setup and air filter location or is that a reult of using that intercool and manifold?
15My old girl Empty Re: My old girl on 29th April 2016, 3:27 pm
TrueRebel
TrueRebel
The turbo is positioned over the top of the gearbox now, so just mounted the intake there so I could use it until a new cold air intake box was made (which I never got round to Embarassed ). The intercooler was one of the first mods that was done to it in about 2003 and at the time intercooler kits were a lot of money so decided to make my own up. No real reason for that set up other than cost and intercooler core size. So just going to try finish off (and tidy up) what I started now as I miss driving it. Its not a finished artical just where I had got to before I left it for a while. Also not happy with some of the choices I made, so probably change a few things.
16My old girl Empty Re: My old girl on 30th April 2016, 8:10 am
Yeah im in the same boat sometimes you just need to get things running as sitting can be a killer too
17My old girl Empty Re: My old girl on 30th April 2016, 10:49 am
BC are ok for price you pay.
4KGmm (F) 3KGmm (R) is not bad for road
plus points with them is proper separate height adjustment so you can set spring preload & corner weights correctly.
Biggest problem with them for fast B road use is strut piston travel is very short so loose a lot of grip on bumpy poor surfaces.
If BC would build custom struts with almost double piston travel range & not dumped too low when fitted they would be way better on road . Custom bilstein 36mm piston inserts are very good but over twice price of BC. Decent set of old Ohlins good too if can find some .
18My old girl Empty Re: My old girl on 3rd May 2016, 8:40 am
TrueRebel
TrueRebel
Brilliant. Thats some good information Very Happy . I will have a look and see what I can find. Thank you. Im thinking about using it mainly as a weekend and track day car. But due to budget probably go for the BC's.
