Gtir Motorsport club » General Discusion » Gtir related Discussion » Pressure bleed brakes
1 Pressure bleed brakes on 2nd May 2016, 8:05 am
joetheeskimo
Anyone know where to get an adapter cap that fits the gtir reservoir as all the ones with my pressure bleeder are too small.
Thanks
2 Re: Pressure bleed brakes on 2nd May 2016, 8:17 am
I am sure it's just a push on one similar to the one in a eezi bleed kit as you say the screw on ones don't fit
3 Re: Pressure bleed brakes on 2nd May 2016, 8:19 am
joetheeskimo
this is the bleed kit ive got.
http://www.screwfix.com/p/gunson-brake-bleeding-kit-14-pcs/33881?kpid=33881&cm_mmc=Google-_-Product%20Listing%20Ads-_-Sales%20Tracking-_-sales%20tracking%20url&cm_mmc=Google-_-Shopping%20-%20Auto%20and%20Cleaning-_-Shopping%20-%20Auto%20and%20Cleaning&gclid=CjwKEAjw9Zu5BRCS_OuVibujhQ0SJAD7t4KrjC8uoiZzTiaasD2TwpuRIG2vUPMPUtWTTYSYvrD6XxoCEk_w_wcB
4 Re: Pressure bleed brakes on 2nd May 2016, 8:36 am
I similar is one of them not a push on type that just goes on obv not. Not sure then mate
5 Re: Pressure bleed brakes on 2nd May 2016, 11:04 am
you would have buy the additional type caps if they do one that would work.
pretty easy bleed brakes with just a small spring hose clamp, hose with a alloy or plastic ball valve (plastic valves borrowed from car washers are good) & jar with little fluid covering the valve, valve reduces back flow & makes job very easy generally & one man possible although way quicker & better job with 2.
Pressure or vacuum style bleeders are ok but you need spend quite decent money have one that fits most stuff & works efficiently .
