Gtir Motorsport club » General Discusion » Gtir related Discussion » Alt
Alt
1Alt  Empty Alt on 2nd May 2016, 9:07 pm
Ok so I have a true 3" elbow not to standard position. But I think it's the same on a stock setup. The long bolt that goes through won't push all the way out either way so alt removal means taking the full bracket off. Has anyone done any mod to make it easier ?
Problem is my elbow dose not alow alt to drop down far enough to get to the bolt on the 3 bolt bracket to change it.
2Alt  Empty Re: Alt on 2nd May 2016, 11:17 pm
Last time I've just hammered it out wit long chisel than ground one side flat so it was easier to ut it back on...
3Alt  Empty Re: Alt on 3rd May 2016, 6:32 pm
Ok so I am thinking out loud. 2 bits of threaded bar or inner ends threaded and a coupler. Say just x2bolts with a shaft. One threaded more than the other. Screw a nut on right  one as you look at it once it's in to centre through bracket and eye on alt. Then coupler screw it well up the thread. put a shorter bolt in from left side screw coupler back over so it joins both then screw nut up to coupler and slight turn against each other will lock it in position. I am yet to try this but might work ? Thoughts ? Sound complicated but ain't really
Like I say if alt fails I can not change it without removing elbow or slacking manifold. And I like the free flow of elbow.
4Alt  Empty Re: Alt on 3rd May 2016, 8:39 pm
How hard is the elbow to get off johnny? Makes sense what you are explaining and will solve your problem. I haven't look but is there enough space for the coupler?
5Alt  Empty Re: Alt on 3rd May 2016, 8:49 pm
Should be as coupler don't need to be more than what 3 nuts wide.
Only reason I brought this up was it was late I had a long drive had work next day alt packed in I got one but what should be a hours work was way more. I have v band from elbow to downpipe but as we know any 3 inch elbow nuts are tight gasket is there and awkward. Plus how long until elbow cools mate. Nuts bolts can be a pain due to heat/rust
6Alt  Empty Re: Alt on 3rd May 2016, 10:50 pm
Didn't you buy a bogdan special elbow?
7Alt  Empty Re: Alt on 4th May 2016, 4:14 pm
I for one of my R's I have more than one mate
8Alt  Empty Re: Alt on 4th May 2016, 4:31 pm
Only say as i have the blackpool ebay elbow and got alternator off. If it's like bogdan or blackpool then you must be farked
9Alt  Empty Re: Alt on 4th May 2016, 6:47 pm
Must be what ?
10Alt  Empty Re: Alt on 4th May 2016, 7:32 pm
I think he means fooked .....lol
11Alt  Empty Re: Alt on 4th May 2016, 7:38 pm
I take it he means if it's not like Blackpool or bogdans. As he says you would be fooked but says he got his off hence getting confused lol
12Alt  Empty Re: Alt on 4th May 2016, 7:45 pm
Missed "not" out of the sentence. Do you have pictures of this elbow?
Yep farked if you have to take manifold off
13Alt  Empty Re: Alt on 5th May 2016, 7:35 pm
Ive modified my alternator bracket but cant confirm just yet how much of a difference it has made. I'll try and look this Saturday.
14Alt  Empty Re: Alt on 5th May 2016, 9:29 pm
Nice one mate how's it all going ?
15Alt  Empty Re: Alt on 7th May 2016, 5:37 am
Very slowly mate, like yourself so many other things seem to keep me busy elsewhere.
16Alt  Empty Re: Alt on 7th May 2016, 7:42 am
That's the trouble here I started building the rotisserie. I have bought new wheels took front brakes off. Wired new dash n that's about it
17Alt  Empty Re: Alt on 7th May 2016, 5:04 pm
Check your whatsapp matey
18Alt  Empty Re: Alt on 7th May 2016, 9:47 pm
Thanks for that today Mate was driving hence my carp replys
19Alt  Empty Re: Alt on 8th May 2016, 6:43 am
No worries, keep up the good work
