Gtir Motorsport club » Tech room » Help and Advice » Rear caliper seal kit
1 Rear caliper seal kit on 3rd May 2016, 5:52 pm
Evenin,
I've found the front seal repair kits but buggered if I can find a rear seal and piston kit. I'm too tight to send them Biggred, checked there site and can't see the kits listed..
Is there another manufacturer that's the same size piston and seals?
Cheers
Gaz
2 Re: Rear caliper seal kit on 3rd May 2016, 6:27 pm
Think I may have found them:
http://brakeparts.co.uk/#!/shop/NISSAN/SUNNY/91-95/SUNNY%20N14%202.0%20GTI-R%204X4%20TURBO/Rear%20-%20Brake%20Calipers%20and%20Wheel%20cylinders
3 Re: Rear caliper seal kit on 3rd May 2016, 6:34 pm
Good find
4 Re: Rear caliper seal kit on 3rd May 2016, 7:07 pm
Ordered both sides being delivered Thursday, will report back thumbsup
5 Re: Rear caliper seal kit on 3rd May 2016, 7:15 pm
looks right, they out of stock so if you get them they were last ones lol .
6 Re: Rear caliper seal kit on 3rd May 2016, 7:31 pm
yep they showed as in stock when I ordered them, thank god I got them need to bleed the brakes this week, hopefully get the lump back in soon! Want to check the bias valve doesnt leak before engine goes in.
Any tips bleeding a completely dry braking system? is it a case of open rear caliper nipples and start pouring fluid into the reservoir unto fluid starts to weep out, then same for front, then go onto bleeding the system?
Ive got no fancy gadgets, good old tube and jar Laughing
Engine nearly there, built up over weekend:
Ended up using Nissan Rings Mr B! Got the others refunded, chap on ebay in lativa sold brand new ones for £90, ring gap was inside the spec so alls good in the end!
7 Re: Rear caliper seal kit on 3rd May 2016, 7:48 pm
Looks well nice and clean
8 Re: Rear caliper seal kit on 3rd May 2016, 7:59 pm
Yeh you can try opening up rears & see if will pump fluid through then do front then go back & do each circuit back to front couple times to make sure all air out. If got abs you may get problems & need loosen lines at abs unit to try shift some air, if all fails you might need a vacuum pump.
Ball valve like get on car washer lines are good on the hose and jar method as cut back on reverse flow & can speed up the bleed process .
Have seen a second car used as vacuum source with long hose to nipple with short clear section and stop valve so can block line before fluid drawn into second engine lol.
Bit of a hillbilly trick & not overly recommended but handy if in a real jam .
Got lucky on piston rings in end, glad got refund & all worked out good & in spec .
9 Re: Rear caliper seal kit on 3rd May 2016, 8:06 pm
Non abs model thankfully so fingers crossed it all goes easy!!
Think I've got ocd car cleaning Laughing I know it's going to get dirty but what the hell l, easy to spot leaks!
10 Re: Rear caliper seal kit on 3rd May 2016, 8:16 pm
I do believe the caliper kits cross with kia hyundia or both, will see if can drag up kit P/N at some point & add to the thread ...
nothing wrong with bit of proper cleaning lol .
11 Re: Rear caliper seal kit on 13th May 2016, 5:26 am
DaniRS
@burrows1980 wrote:Evenin,
Cheers
Gaz
Hi, i found this: http://biggred.co.uk/brakecaliperrepairkit_brk203410 Cool
12 Re: Rear caliper seal kit on 13th May 2016, 7:11 am
I meant to update this but forgot, biggred emailed me back with the rear kit part numbers, but I'd already ordered, received and fitted the other ones.  This is there email:
Hi we sell both item separately they are available on our website, if you go to the top right hand page of the website and type
BRP233416 for the piston and BRK203434 for the kit
Regards
John Smith
Director
Bigg Red Ltd
0044 1905 428793
Bit more expensive than what I paid. Oh and had to make yet another tool
Yep a caliper piston wind in tool Laughing worked a treat! A butchered angle grinder key tool welded to a bolt Laughing
13 Re: Rear caliper seal kit on 13th May 2016, 7:46 am
That tool is quite creative Smile
14 Re: Rear caliper seal kit on 13th May 2016, 8:40 am
Did the trick, could be bothered spending more money on a tool I'll use once in a blue moon, plus the wife had gone out in the car and the battery was flat on my van Laughing
Thought I could do it with long nose pliers at first but nope!
