Help!
Go to page : Previous  1 ... 7 ... 10, 11, 12, 13, 14  Next
Go down  Message [Page 11 of 14]
251Help!  - Page 11 Empty Re: Help! on 25th June 2016, 11:04 am
Here's the video
The reason why it sticks is because of rust on all the moving surfaces of the reverse mechanism.
Help!  - Page 11 Img_2038
Help!  - Page 11 Img_2040
Help!  - Page 11 Img_2039
Help!  - Page 11 Img_2041
Help!  - Page 11 Img_2037
Help!  - Page 11 Img_2036
Help!  - Page 11 Img_2042
Help!  - Page 11 Img_2044
I don't know why this is all rusty but the builder should have removed the rust and polished the surfaces to get smooth  contacts.
The builder also didn't clean out the gearbox from previous failures so all those debris would've further jammed the mechanism.
So, I'm now certain  your builder is at fault for your failures.
252Help!  - Page 11 Empty Re: Help! on 25th June 2016, 11:21 am
You may find if the box is on the side like normal operation it may play up more often. Gravity won't be trying to pull the gear down and there more friction on the slide.
253Help!  - Page 11 Empty Re: Help! on 25th June 2016, 12:40 pm
Oil & windage will make huge difference too but that definitely right base cause of failure.
Any damage signs on input gear & shafts 12&3 & all hubs from debris that been carried about in the oil ! 3rd must of taken some shock loads as idler catched on the syncro outer reverse collar .
254Help!  - Page 11 Empty Re: Help! on 25th June 2016, 12:43 pm
@ducie54 wrote:You may find if the box is on the side like normal operation it may play up more often. Gravity won't be trying to pull the gear down and there more friction on the slide.
Thats a good point, Very Happy
255Help!  - Page 11 Empty Re: Help! on 25th June 2016, 2:33 pm
Very good effort tho mate Pete must be over the moon to of had your help as once over even after I said don't he was tempted to return to the builder would of been more money wasted
256Help!  - Page 11 Empty Re: Help! on 25th June 2016, 2:43 pm
@johnny gtir wrote:Very good effort  tho mate Pete must be over the moon to of had your help as once over even after I said don't he was tempted to return to the builder would of been more money wasted
Over the moon? I genuinely can't thank him enough for all this!
So is the conclusion that it's the builders fault due to removing the mechanism Neil? I understand now seeing the video why there was so much damage to the edge of the gear
257Help!  - Page 11 Empty Re: Help! on 25th June 2016, 2:54 pm
I've Really happy he offered like you said when someone is abit more local and you been there before you might of went back to him again and he would of charged you more money again. Neil is learning us all a lot
258Help!  - Page 11 Empty Re: Help! on 25th June 2016, 3:14 pm
The builder removed the 5th/reverse switch stop not the reverse interlock as i originally thought, this wasnt the cause.
The interlocks were all fitted and working which surprised me so that wasnt the cause either and i was a bit stumped.
So i just did a few shifts and thats when i realised that it was the sliding idler gear that was sticking, even tho the interlocks snapped into neutral positions.
So not the builders fault for removing the reverse switch, but imo the builders fault for the following;
Fitting a rusty reverse mechanism  Evil or Very Mad
Not disassembling and cleaning all parts  Evil or Very Mad
Not measuring floats, clearances or wear limits  Evil or Very Mad
259Help!  - Page 11 Empty Re: Help! on 30th June 2016, 7:25 pm
Hey Pete,
I started stripping your 2nd box and the main shaft us fubar
Help!  - Page 11 Img_2048
260Help!  - Page 11 Empty Re: Help! on 30th June 2016, 7:29 pm
What's wrong with it learing a lot from this thread thanks
261Help!  - Page 11 Empty Re: Help! on 30th June 2016, 7:48 pm
I can see a massive chip out of it
262Help!  - Page 11 Empty Re: Help! on 30th June 2016, 8:09 pm
See it now
263Help!  - Page 11 Empty Re: Help! on 30th June 2016, 8:10 pm
Gear next to bearing, well that's what I can see, the gear next to it has marks on the teeth but not sure if they suppose to be there?
264Help!  - Page 11 Empty Re: Help! on 30th June 2016, 8:10 pm
Doh too slow Laughing
265Help!  - Page 11 Empty Re: Help! on 30th June 2016, 8:17 pm
@burrows1980 wrote:Gear next to bearing, well that's what I can see, the gear next to it has marks on the teeth but not sure if they suppose to be there?
Those marks on the toplands (what us gear chaps call the surface at the tips) are made by the hobbing machine during manufacture.
Very Happy
266Help!  - Page 11 Empty Re: Help! on 4th July 2016, 5:50 pm
Thus photo sums up why it's so important to completely strip down the shaft assemblies. Although it looked clean on the outside , under the cone recess was a debris trap , No
Help!  - Page 11 Img_2049
267Help!  - Page 11 Empty Re: Help! on 4th July 2016, 7:01 pm
Is this debris from a previous Failure then? I.e when I've smashed 3rd and 4th gears?
268Help!  - Page 11 Empty Re: Help! on 5th July 2016, 8:28 am
@PartyPete wrote:Is this debris from a previous Failure then? I.e when I've smashed 3rd and 4th gears?
It's too late to tell mate, but there would've been a lot of nasty shit flying round after that rebuild.
I've brought the mainshaft from your 2nd box to work to pull off the gears and get to the synchro parts. Hopefully they'll still be in spec. Very Happy
269Help!  - Page 11 Empty Re: Help! on 5th July 2016, 9:44 am
Great stuff cheers Very Happy
270Help!  - Page 11 Empty Re: Help! on 5th July 2016, 10:51 am
cant beleive none of you fookers have given Neil a rep point/s for this as hes gone well out his way with sorting things out for the gearbox slayer lol
So ive just awarded you some mr cosmos which more than makes up for the neg one ive left you also haha
Due to the vid being extremely boring have had to leave neg feedback for that, no smut, no violence and certainly no funny bits so dont give up the day job lol  Very Happy
271Help!  - Page 11 Empty Re: Help! on 5th July 2016, 11:53 am
@GTI-R US wrote:cant beleive none of you fookers have given Neil a rep point/s for this as hes gone well out his way with sorting things out for the gearbox slayer lol
Thanks Bob, about time i got a bit of apprecia-fucking-ation round here well done
In my next video i'll dress as a mechanic with my fingers deep inside Pete's box while my wife pulls on his shaft. Yah, yah, fantashteesh censored
272Help!  - Page 11 Empty Re: Help! on 5th July 2016, 12:56 pm
Boring video yoursofunny tight git Laughing
273Help!  - Page 11 Empty Re: Help! on 5th July 2016, 5:05 pm
Cheeky fookers some of us left rep points even right at the start page 3. And I am more than willing to hold the camera for next video
274Help!  - Page 11 Empty Re: Help! on 5th July 2016, 5:41 pm
I had to give him a negative rep point for turning up to a meet with MG seat covers on his R. I know he is northern but come on yoursofunny
In all seriousness great effort mate
275Help!  - Page 11 Empty Re: Help! on 5th July 2016, 5:50 pm
censored
It would be like some weird Geordie shore episode
Back to top  Message [Page 11 of 14]
