Gtir Motorsport club » General Discusion » Gtir related Discussion » Oil Temperature Sender
1Oil Temperature Sender Empty Oil Temperature Sender on 10th May 2016, 5:27 pm
joetheeskimo
joetheeskimo
Does anyone know where i can buy an oil temperature sender for my GTIR.
Thanks
2Oil Temperature Sender Empty Re: Oil Temperature Sender on 10th May 2016, 7:36 pm
I checked icp and the only have oil pressure switch ....
3Oil Temperature Sender Empty Re: Oil Temperature Sender on 10th May 2016, 7:49 pm
May actually be worth enquiring with Nissan?
4Oil Temperature Sender Empty Re: Oil Temperature Sender on 10th May 2016, 8:21 pm
I'm on my own phone at the moment, but have a look in the service manual for the range of the sensor. Should be pretty common I'd imagine.
5Oil Temperature Sender Empty Re: Oil Temperature Sender on 10th May 2016, 9:11 pm
I saw s15 sr20det ones ...
6Oil Temperature Sender Empty Re: Oil Temperature Sender on 14th May 2016, 1:58 pm
joetheeskimo
joetheeskimo
just been to nissan to buy one. £55.....quite expensive but safer to know i can check the oil temperatures
7Oil Temperature Sender Empty Re: Oil Temperature Sender on 29th June 2016, 2:06 pm
Revival but which sensor is the oil temp? I think mine isn't working can't say I noticed the gauge working. Now the engines out again might as well check it out. I thought it worked of the oil pressure sender thing?
8Oil Temperature Sender Empty Re: Oil Temperature Sender on 29th June 2016, 3:16 pm
location
Oil Temperature Sender Oil_te10
test
Oil Temperature Sender Oil_te11
9Oil Temperature Sender Empty Re: Oil Temperature Sender on 29th June 2016, 4:44 pm
Great stuff, cheers Mr B will check the resistance tonight!! I was fixed on checking the pressure Laughing only noticed on a vid I did that the temp needle hadn't moved, but can't remember if the vid was from a cold start.. Easy to check now.
10Oil Temperature Sender Empty Re: Oil Temperature Sender on 29th June 2016, 4:51 pm
You can also use resistors on sensor wire to ground to rough test gauge accuracy/function .
Also worth noting sensor is same as on GTR ( 2075M . P/N 2507505U00 . M12x1.25 NTC )
