Gtir Motorsport club » Tech room » Help and Advice » Steering screech when on full lock?
1 Steering screech when on full lock? on 11th May 2016, 8:03 am
Bit of strange one this.
If i reach full steering lock there's a little high pitched screech which last for about a second then it stops.
When i ran in the engine a few weeks back, i went lock to lock a few time as advised to bleed the pump. Fluid level is spot on.
I can only think of the pulley bearing on it's way out?
Shocked
2 Re: Steering screech when on full lock? on 11th May 2016, 11:15 am
GTIR James
Belt is loose tighten it up.
3 Re: Steering screech when on full lock? on 11th May 2016, 12:37 pm
Mine usually does this after I've had the engine out, I seem to top it up but after a short while it does the same, usually dropping a bit more fluid in stops it...
4 Re: Steering screech when on full lock? on 11th May 2016, 5:40 pm
Yep slight bit air locked or belt slip
5 Re: Steering screech when on full lock? on 18th May 2016, 9:07 pm
Yep, belt slip.
Tightened it up a bit and job done,
Thanks
Very Happy
6 Re: Steering screech when on full lock? on 18th May 2016, 10:10 pm
Nice easy fix ..... if all jobs were the same Laughing
7 Re: Steering screech when on full lock? on 19th May 2016, 8:07 am
haha, yes i wish
Smile
