Gtir Motorsport club » Tech room » Help and Advice » Power Steering Cooler
1 Power Steering Cooler on 17th May 2016, 5:21 pm
Hi,
Can anyone take a pic or has a pic of where exactly the cooler pipe fixes to at the front of the car please.
When I put the FMIC on 10 years ago I bent the cooler up and out the way, as I'm going back to the TMIC I need to fix it back. I think I must be missing a bracket or something! There's two rubber mount brackets on it but that's it. I defo bent the cooler pipe so need to straighten it out.
Gaz
2 Re: Power Steering Cooler on 17th May 2016, 5:31 pm
This is currently what I've got
I'm assuming the kinky bit Shocked goes around the center bonnet latch support
3 Re: Power Steering Cooler on 17th May 2016, 6:06 pm
Your missing 2 xbrackets ..
They bolt to the bracket that then bolts to the front cross member
4 Re: Power Steering Cooler on 17th May 2016, 6:12 pm
I've got 2 brackets which bolt it to the cross member under the rad.
Sure someone will turn up a better picture....
5 Re: Power Steering Cooler on 17th May 2016, 6:25 pm
Ahhh makes a bit of sense now! Anyone got any spare brackets Laughing
