Gtir Motorsport club » General Discusion » Gtir related Discussion » Rocker cover
Rocker cover
1Rocker cover  Empty Rocker cover on 20th May 2016, 6:24 pm
Gti-r dannyboy
How or what is the best thing to seal the rocker cover with?
Also under boost it seems to run on three cylinders and stuttering any ideas??
2Rocker cover  Empty Re: Rocker cover on 20th May 2016, 6:34 pm
Rocker cover gasket and a small amount of sealant on the cam recesses
3Rocker cover  Empty Re: Rocker cover on 20th May 2016, 6:35 pm
Under boost all the time or if you accelerate slow is it ok ? What plugs and gaps you running
4Rocker cover  Empty Re: Rocker cover on 20th May 2016, 6:40 pm
Gti-r dannyboy
I have that icp gasket off ebay (yes ebay) lol ready to go on not sure if it's going to be any good tho!!
5Rocker cover  Empty Re: Rocker cover on 20th May 2016, 6:45 pm
Gti-r dannyboy
all good on low boost just high revs on high boost, plugs and gaps i wouldnt no mate.
6Rocker cover  Empty Re: Rocker cover on 20th May 2016, 7:07 pm
Yes there gaskets are fine. As I say the 2 dip bits and the corners only if you think it needs it. What has the problem just started or ?
7Rocker cover  Empty Re: Rocker cover on 20th May 2016, 7:33 pm
Gti-r dannyboy
Cool i will fit that tomorrow then, that for helping me AGAIN johnny!! Not drove it since last October so hoping it will clear up on its own after clocking up some miles init.
8Rocker cover  Empty Re: Rocker cover on 20th May 2016, 7:40 pm
@johnny gtir wrote:Rocker cover gasket and a small amount of sealant on the cam recesses
I second that,
Also dont forget to nip up the cover bolts after a few days as they may relax a bit and weap into the spark plug tubes.
Very Happy
9Rocker cover  Empty Re: Rocker cover on 20th May 2016, 7:53 pm
As said check the plugs etc change them if possible as could be coked up. Also how high in the revs check for any fault codes. Do all the basics first :-)
10Rocker cover  Empty Re: Rocker cover on 20th May 2016, 9:03 pm
Gti-r dannyboy
Never done a fault code, whats one if them? Yes i am pretty clueless lol
11Rocker cover  Empty Re: Rocker cover on 20th May 2016, 11:01 pm
You do it with a paper clip bridging two pins on the obd port its located where the fuses are drivers side ...
12Rocker cover  Empty Re: Rocker cover on 20th May 2016, 11:03 pm
13Rocker cover  Empty Re: Rocker cover on 21st May 2016, 8:53 am
gtir350
If you still have that motec ecu you can't use the standard falt code check.
14Rocker cover  Empty Re: Rocker cover on 21st May 2016, 12:11 pm
Gti-r dannyboy
Ahh i wont try that then
