Gtir Motorsport club » Tech room » Help and Advice » engine misfire
engine misfire
1 engine misfire on 25th May 2016, 11:44 am
I wouldn't say misfire sounds more like a limiter but the car idles and drives fine except it
Cuts in a 4000 rpm with throttle down but if i ease throttle in i can drive normal except full foot throttle under load.
I haven't checked anytthing yet as this was last night it happened.
Feels the same symptoms as my old mk2 golf which had an ignition amplifer which went dodgy.
2 Re: engine misfire on 25th May 2016, 11:57 am
More than likely it's a dodgy afm or connection to it
3 Re: engine misfire on 25th May 2016, 12:49 pm
Do a fault code check.
Check the vacuum on the fpr too.
4 Re: engine misfire on 25th May 2016, 12:51 pm
Just come back from the ring so lots of flinging it about could have minced up a connection i guess. Just drove it now and it's driving fine but components aren't warmed up.
Just bought ig leads, dizzy cap and rotor arm and an ig amplifier. Prior to that in low speeds always felt abit hesitant at low speeds underload but thats another issue
Thanks bob
5 Re: engine misfire on 27th May 2016, 6:14 pm
Ok so it's none of the above is was
Wait for it
Water down the plug hole. Should really look sometimes.
Massive down pour driving back from germany and down pour here with no winter blanks in as i took them out before the track. What a melon.
Hey anyone know where i can get a spark plug cover?
Also another weird thing with the temp gauge. As i floor it the temp gauge drops back and forth like a boost gauge. Going to take the clocks out and check connections.
