Gtir Motorsport club » General Discusion » Gtir related Discussion » Exhaust gasket
Exhaust gasket
1Exhaust gasket Empty Exhaust gasket on 20th June 2016, 9:52 pm
Will I need to replace the elbow to down pipe gasket when I drop the engine this Friday? It's only run up to operating temp, wondering if I can save a few £ same on the decat pipe..
2Exhaust gasket Empty Re: Exhaust gasket on 20th June 2016, 9:58 pm
What type of gaskets have you used ???
3Exhaust gasket Empty Re: Exhaust gasket on 20th June 2016, 10:33 pm
This type mate
https://www.ebay.co.uk/itm/330988827775
4Exhaust gasket Empty Re: Exhaust gasket on 20th June 2016, 10:41 pm
I cant see it being a problem .... its not like its been well used either ....
5Exhaust gasket Empty Re: Exhaust gasket on 20th June 2016, 11:04 pm
If its seen little use I wouldn't be replacing it mate.
6Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 7:02 am
Cool, cheers chaps
7Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 9:03 am
Yeah those ones last a while plus you can at a push do it without taking anything off anyway so worth a go
8Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 11:51 am
Should be ok but easier to replace than re use and then find to change it
9Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 12:22 pm
Johhny you are tied into that throw away society recycling is the way forward! I have used the same oil filter for 5 oil changes its fine... lol
10Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 1:31 pm
^ yoursofunny
11Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 4:23 pm
@shroom wrote:Johhny you are tied into that throw away society recycling is the way forward! I have used the same oil filter for 5 oil changes its fine... lol
what and the same oil or do you get new from the chip shop as it's new to a engine.
Maybe I have more money than sense. ( not the case) maybe I have no Sense possibility
No I just think it won't clamp exactully right but dose work but i hate doing things twice if it fails it's not the end of the world.
For all you recycle tips and how to save money phone shroom on 0797 6123 He has tea bags hanging in the line ready for that 6th brew as we speak.
Did do a job once for someone who kept his used bath water and used it to flush his toilet but the bath tide ring was unreal
12Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 8:47 pm
Thats sounds pretty grim johnny ..... Laughing
I dont think you will have any problems or issue with the gasket if all you have done is start it up once ...
13Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 9:15 pm
@johnny gtir wrote: For all you recycle tips and how to save money phone shroom on 0797   6123   He has tea bags hanging in the line ready for that 6th brew as we speak.
^ yoursofunny  drink
14Exhaust gasket Empty Re: Exhaust gasket on 21st June 2016, 10:12 pm
Haha you know me too well. I also often use tigerseal not just to fix engine mounts but also repair cracking cambelts its always worked. I only use chip fat for engine run ins Johnny as its mineral based. Works a treat!
I have also never had a problem with replacing fuses with tin foil expext for one cabin fire in an old cavalier but I put that down to too many farts on the seat
