Gtir Motorsport club » Tech room » Help and Advice » Apexi and knock sensor
1 Apexi and knock sensor on 25th June 2016, 2:57 pm
I'm putting mates car back together and I've found mashed up plug with no home terminals are badly corroded and i can2push it anywhere but it looks like it would go on knock sensor which I can't find plug for... Now question is does apexi power fc need/usind factory knock sensor?? Oh and that other plug with single wire that for idle speed control yes?
2 Re: Apexi and knock sensor on 25th June 2016, 3:01 pm
Apexi power fc can run if set without the knock sensor it picks knock up through Ecu and flashes engine management light to warn you
3 Re: Apexi and knock sensor on 25th June 2016, 3:12 pm
Ok single wire goes to knock sensor and one I couldn't figure out goes to cold start dev... But why it wouldn't be plugged in??
4 Re: Apexi and knock sensor on 28th June 2016, 9:47 am
apexi pfc uses knock sensor same as a stock ecu except it will not pull ignition out or pull back boost if knock is detected.
As Johnny rightly said knock detection will show up through engine management light flickering.
The knock function can be set or turned off completely through the mapping software if needs be but not really a good idea to do so.
5 Re: Apexi and knock sensor on 28th June 2016, 9:55 am
Thanks for info. It confused me slightly cos somebody else stripped wiring and I was rebuilding it and just found 2 pin plug wth no home and badly corroded figured out it was for cold start device cleaned plugged bac in see gow it'll go...
