Gtir Motorsport club » Tech room » Help and Advice » handbrake cables
handbrake cables
1handbrake cables Empty handbrake cables on 26th June 2016, 3:29 pm
mojo
hi there i was wondering if anyone can help me . I have been trying to get handbrake cables for my gtir with no luck so far. can anyone point me in the right direction ? i have blue print part numbers for them but my local car part supplier says they are showing as discontinued. I haven't tried nissan yet but not sure if they will still stock them. cheers in advance for any help.
2handbrake cables Empty Re: handbrake cables on 26th June 2016, 3:30 pm
I have some decent used ones i would sell.
Not sure you can get all new sections anymore.
Nissan are around £70 each section.
3handbrake cables Empty Re: handbrake cables on 26th June 2016, 3:35 pm
mojo
hi stu thanks for the quick response. I was hoping to get new replacement cables but if i can not then i will deff get second hand ones .
4handbrake cables Empty Re: handbrake cables on 26th June 2016, 6:33 pm
herth & Buss (Jakoparts) did them as well .
I'll try put up part numbers (you'll find one thread on it in parts wanted section)
Blueprint ones will be old on shelf stock only, if hunt around online & ebay you should find front section easy enough & possibly one rear .
Best affordable bet is good used but will add Herth & Buss details tomorrow if get time tomorrow .
5handbrake cables Empty Re: handbrake cables on 26th June 2016, 8:36 pm
This is good to know, I need to replace mine aswell. Didn't know they are in 2 sections. If only you know if just one section needed replacing.
6handbrake cables Empty Re: handbrake cables on 26th June 2016, 9:25 pm
Mine need doing as well. It just scraped through its MOT.
I was planning on doing it over the Winter when i hibernate the R.
Blueprint ones are £15 a corner on ebay,
Very Happy
7handbrake cables Empty Re: handbrake cables on 26th June 2016, 9:35 pm
Very Happy
Have you got a link to them?
Pretty sure you could only get one side from blueprint now and they were out of stock.
You sure they are for the gtir that you have seen?
8handbrake cables Empty Re: handbrake cables on 27th June 2016, 7:56 am
@Stu wrote:
Very Happy
Front,
http://www.ebay.co.uk/itm/Nissan-Sunny-MK3-2-0-GTI-R-4x4-Genuine-First-Line-Front-Handbrake-Cable-/291782347978?hash=item43ef954cca
Left
http://www.ebay.co.uk/itm/291775589572?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Right,
None there!
9handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:29 am
Part cross reference numbers pdf >
https://drive.google.com/file/d/0B7Ub2apq5-pfUEJjVi13OVdhX3M/view?usp=sharing
Details:
Front cable:
oem 3640250J10
Blueprint ADN146207
this front cable used on lots of nissans and easy get as many patern brands do it, ebay link >
http://www.ebay.co.uk/itm/1x-Blue-Print-Brake-Cable-ADN146207-/191621694271
Rear right (OS):
oem 3653069C00 . alternative 3653069C10
Blueprint ADN146170
No link
Rear left (NS):
oem 3653169C00 alternative 3653169C10
Blueprint ADN146169
ebay link >
http://www.ebay.co.uk/itm/Nissan-Sunny-MK3-2-0-GTI-R-4x4-Blue-Print-Rear-Left-Handbrake-Brake-Cable-/291775589572
Rear right is tricky one but if hunt about with all part numbers you may find source in your area or shipping available .
Can find rear right listed on online parts store (google ADN146170) but may find actually have no stock.
Could be worth having a word with ICP & supplying them the part numbers as they maybe able get them direct from Japan/manufacturer sources !
10handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:02 am
Just based on an assumption, whats more likely to stretch, the front or the rear or it doesn't really matter?
11handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:02 am
Very handy links - rep for you, even though you have too many Laughing
12handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:07 am
I think most trouble for uk likely be corrosion related & sticky cables.
Lot of issue if handbrake too high & adjustment run out on front cable is fact it the rear caliper pistons not auto adjusting correctly .
13handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:17 am
Ive got my rears rebuilt so thinking it must be the cable? maybe Ill just buy the front section and see how it goes Smile
14handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:52 am
front takes more load but rears are longer & not straight run so stretch can be greater, I never had or seen cable issue, If cables physically good I would probably mod font cable to reduce slack & bring nut adjuster back in range, 2 I dealt with which had handbrake issue both came down to rear caliper piston adjuster mechanism not working, if tighten it up & comes slack again then generally caliper auto adjust issue & pistons sitting off disc too far or handbrake lever snail cam worn or turned to mush from corrosion, cables here tend keep well as dry climate & we don't use handbrakes much lol, when parking in malls, work car parks, residential parking we normally leave off & chock wheel so cars can be rolled by security to allow others in & out (parking is like a puzzle block game here lol)
15handbrake cables Empty Re: handbrake cables on 27th June 2016, 6:37 pm
As B says seizure of cables is a massive problem in the uk on all vehicles and some of the pattern parts are shit my brothers Astra van had 3 in no time. I just done a one on my R for its mot was rear driver side but was well seized. But car had stood a couple year earlier
16handbrake cables Empty Re: handbrake cables on 27th June 2016, 6:39 pm
mojo
hi all i thought i would let anyone that needing handbrake cables that they are still available from nissan. including vat it comes to £149.31 for the two rear sections .pricey but needs must. thanks for the help guys :]
17handbrake cables Empty Re: handbrake cables on 27th June 2016, 6:54 pm
That is Steep add your part numbers to here please for people reading in the future
18handbrake cables Empty Re: handbrake cables on 27th June 2016, 7:25 pm
Is there some way to test if its the left, right or front?
Mines siezed and barely ratchets up 2 notches and i dont fancy replacing the lot.
Very Happy
19handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:04 pm
Disconect it from calipers see if they move or Jack car up see if the wheels lock when it's pulled on
20handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:06 pm
Cheers, ill give that a go this weekend, Very Happy
21handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:09 pm
Disconnect cables from front and test each one by pulling ends back and forth to find seized/sticky one.
Take them off and hang them up and run release oil into them or soak in release oil and if works clean up and use some waxoil diluted with release oil to protect them a bit before final assembly.
If spend time hunting web and calling factors you may get lucky on a rear right, I see one online UK company listing it available but may find not once paid ! Could be done for under £60 and possibly under £50 If do find right Blueprint cable and quality on those good too.
Worth checking rear callipers too as nice handbrake needs them in A1 order .
22handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:16 pm
Do some handbrake turns around mcdonnalds that might free it up.
23handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:33 pm
So if I see someone in Micky D'z doing handbrake turns and got a lady boy & a sheep in the R and tube of pile cream on dash it probably be you or possibly your dad as he likes driving your R lol ...
24handbrake cables Empty Re: handbrake cables on 27th June 2016, 8:37 pm
Haha na I only did that sort of stuff in PartyPetes car before I sold it, launched it loads and had loads of mutton sluts in there. The pile cream helped stop the dash cracking though it was quite useful.
25handbrake cables Empty Re: handbrake cables on 27th June 2016, 9:10 pm
Good info! Maybe I'll just mod the front cable, easier lol.
You know the hand brake is good when it holds the Macca's trays under the back wheels of your fwd daily driver Laughing
