Gtir Motorsport club » Tech room » Help and Advice » handbrake cables
handbrake cables
26handbrake cables - Page 2 Empty Re: handbrake cables on 27th June 2016, 9:20 pm
Blimey thats a blast from the past woody brings back fond memories in my nova Laughing
27handbrake cables - Page 2 Empty Re: handbrake cables on 27th June 2016, 9:30 pm
Haha I know right, we ended up making metal ones back in the day, lasted longer and put out some decent sparks Laughing
28handbrake cables - Page 2 Empty Re: handbrake cables on 27th June 2016, 9:52 pm
friend I know has this thing in his lockup lol weird thing to behold! dont know what he is doing with it
29handbrake cables - Page 2 Empty Re: handbrake cables on 27th June 2016, 10:24 pm
Thats alot of work to make it rear wheel drive you know what lumps in it shroom ....???
30handbrake cables - Page 2 Empty Re: handbrake cables on 27th June 2016, 11:00 pm
Listen to the sound of that thing!
31handbrake cables - Page 2 Empty Re: handbrake cables on 28th June 2016, 8:03 am
Yeah the engine is in the boot, its really just a nova shell and 2 front seats then sectioned off in the back with the engine. Its a redtop 2 litre vauxhall engine its not turbo as it wasnt needed!
32handbrake cables - Page 2 Empty Re: handbrake cables on 28th June 2016, 8:40 am
Thats pretty cool, looks like a good thrasher from the video.
33handbrake cables - Page 2 Empty Re: handbrake cables on 13th August 2016, 9:36 am
Compared the length of blueprint cable to the standard cable and in my case they were the same length, so a new front cable wasnt going to solve my problem.
However not sure if anyone else has tried fitting the Blueprint ADN146207 front cable. I discovered this arvo the standard cable has a square end but the blueprint cable has a hex end and doesnt fit into the handbrake assembly. I tried sanding it down but took too much off so the cable twisted while fitting.
handbrake cables - Page 2 IMG_3052
What i ended up doing was making a 13mm spacer which keeps the square part of the cable just inside the handbrake assembly to prevent it from twisting. Made a huge difference and my handbrake is within normal range now.
handbrake cables - Page 2 IMG_3056
34handbrake cables - Page 2 Empty Re: handbrake cables on 13th August 2016, 11:25 am
Nice little clever mod there Woody Wink
35handbrake cables - Page 2 Empty Re: handbrake cables on 13th August 2016, 11:44 am
Thanks Stu Smile
Another tip is save yourself time and remove the centre middle console, I was lazy and tried leaving it in, was a pain in the arse until i removed it Laughing
36handbrake cables - Page 2 Empty Re: handbrake cables on 13th August 2016, 3:37 pm
@gtir_woody wrote:Thanks Stu Smile
Haha yeah just 6 screws and its out Smile
37handbrake cables - Page 2 Empty Re: handbrake cables on 11th December 2016, 3:33 pm
I need a cable now aswell. Lh caliper cable is siezed plus the clips are missing aswell
38handbrake cables - Page 2 Empty Re: handbrake cables on 11th December 2016, 3:48 pm
main dealer I expect as blueprint ones discontinued and stock gone unless get super lucky.
maybe put a wanted post up for good used one and clips you need and see where takes you.
Cable at dealer around £80 to £100 mark I think. If not heavily corroded you can normally free them as mentioned page1 but it never going be A1 and likely play up again in time.
39handbrake cables - Page 2 Empty Re: handbrake cables on 11th December 2016, 7:10 pm
Had issues over the last few weeks i noticed the brakes were locking on. I saw this thread before and thinking my cables are fine but now this bollocks Sad
I'll see if i can take it off and lube it probably won't last like you said. I did put up a few posts on bookface but no hits yet.
40handbrake cables - Page 2 Empty Re: handbrake cables on 11th December 2016, 7:18 pm
You might need to refurb the rear callipers too.
The hand brake cam might be binding. There's a thread on this somewhere and i think a company called Bigg Red does them.
This is one of the jobs on my list over the Winter.
41handbrake cables - Page 2 Empty Re: handbrake cables on 11th December 2016, 8:07 pm
I looked at that when i took the cables off and the mechanism is on the stops and pushes back and forth fine. Looks like just the cables up the swanny
42handbrake cables - Page 2 Empty Re: handbrake cables on 12th December 2016, 7:28 am
Is the cable obviously real tight when try pull by hand through sheath.
Problem on calipers can be the slack/wear adjuster rod on the piston causing it snag and not release.
with uk climate and road salt it wouldn't surprise me the cables are not great.
taking cables off and feed release oil and atf fluid in can help massively but takes time and need them hanging until works all way through.
If caliper health unknown it good thing recon them as effects brake pedal feel massively and also the handbrake cams are normally a mixture of rusted sludge and wear which don't help handbrake function and auto piston adjustment function.
43handbrake cables - Page 2 Empty Re: handbrake cables on 12th December 2016, 6:33 pm
Yes siezed in but it did move alittle then sieze. Take it off wednesday and see if i can free it up. Right pain in the ass on a wet road on your back but thats tomorrows job Sad
44handbrake cables - Page 2 Empty Re: handbrake cables on 12th December 2016, 7:36 pm
I was going to say jack it up and test wheel jamming or not holding on handbrake for that matter
45handbrake cables - Page 2 Empty Re: handbrake cables on 13th December 2016, 4:02 pm
Took it off put it in a vice and pulled it one way then it fully siezed in. Getting one made out of my one at a cost of 66quid which isn't bad and only down the road.
Last edited by mc_hawkings24 on 13th December 2016, 8:50 pm; edited 1 time in total
46handbrake cables - Page 2 Empty Re: handbrake cables on 13th December 2016, 5:13 pm
^ that sounds useful service, details on that could be useful for other UK members as got be a few with less than great cables now .
47handbrake cables - Page 2 Empty Re: handbrake cables on 13th December 2016, 8:59 pm
http://www.venhill.co.uk/
Based in dorking but will see what the quality is like when it's done. Only thought when i handed it over that i should've had the other side done so will get that done aswell.
48handbrake cables - Page 2 Empty Re: handbrake cables on 22nd December 2016, 3:54 pm
I haven't tried to order them but this place appears to have in stock; might be worth a try:
http://www.buycarparts.co.uk/vaico/873419
49handbrake cables - Page 2 Empty Re: handbrake cables on 23rd December 2016, 9:54 am
That part not matching oem p/n even as indirect match.
only other ones showing direct match to oem 3653069C00 or 3653069C10 are >
Spidan 43424
Kavo Parts BHC6537
Remkaflex 741015
Jakoparts J3931060
Herth & Buss J3931060
worth physically comparing though as small differences maybe easily modded and is likely something a workable match perhaps !
50handbrake cables - Page 2 Empty Re: handbrake cables on 24th December 2016, 10:49 am
Hmmmm well i got it back yeaterday so christmas eve's task is to fit it
