Gtir Motorsport club » Tech room » Gearbox section » Blue Print Clutch Kit - ADN13069
1Blue Print Clutch Kit - ADN13069 Empty Blue Print Clutch Kit - ADN13069 on 26th June 2016, 6:05 pm
Sharing some useful info regarding my experience with the BP kit.  I bought it as I found an absolute bargain on Amazon, got delivered looked spot on, same as OEM spec kit.  Fitted it not thinking too much about it, first startup of the car pressed clutch only to hear this:
Not good!! Thinking I had damaged it trying to get the gearbox and transfer on at the same time,  bought an endoscope to see what was going on
Looked like something was cracked, so dropped the engine expecting the worst, but only to find nothing wrong with the disc or cover
Blue Print Clutch Kit - ADN13069 108B63E3-BEDC-471F-965D-2D1DA1BC1D74_zpsn9xlbspc
Blue Print Clutch Kit - ADN13069 8F440839-91CC-45B1-8A64-046BD451324B_zpsi2ktnwsp
Blue Print Clutch Kit - ADN13069 38ED4170-1E59-4247-A79B-2D78595B1D9F_zpskmhmc4ib
Slightly bemused of what the noise could be I took a closer look then noticed this
Blue Print Clutch Kit - ADN13069 205BC637-C185-4CF2-BBC1-61AF5D61F7E3_zpsdz2thtby
A gouge out of the casing, popped the clutch cover in and saw the edges were catching on it to the point a chunk had already been carved out.
Advice from Mr B and Ducie54 took the grinder to the casing and clutch cover, also help of a hammer to bend the 3 tabs over more before shaping with the grinder.
Blue Print Clutch Kit - ADN13069 FDBC52D8-2190-489A-B854-9F21020708DD_zpsuv78h1z1
The tabs that I hammered back, gave more clearance just doing that!
Before
Blue Print Clutch Kit - ADN13069 D25EA691-E0C1-495E-9122-FE4808133052_zpspyfjqlft
After
Blue Print Clutch Kit - ADN13069 46A4642A-45E7-456E-B86E-4CA0987B78F4_zpswawg1ijw
Blue Print Clutch Kit - ADN13069 FAA5456B-54BB-4540-A50C-0A8A525157E9_zpsnfholxra
Vid below is with the grinding of the cover
Casing ground
Blue Print Clutch Kit - ADN13069 A0FC588A-62A7-4535-84E1-AADD5E42C3A7_zpssjvaarty
Couldn't get the angle to show how much gap there is now, but its around 3mm so plenty
Blue Print Clutch Kit - ADN13069 2AEC20BC-7903-49D6-9946-8573D3F12498_zpsovqgnnrv
This vid shows the casing ground to create a lot more clearance
Blue Print Clutch Kit - ADN13069 472e499f-038d-4de9-a4cc-4e4deae22c4d_zps0j8gnea8
Hope this helps someone else before fitting a BP clutch or even after if you develop a grinding noise!
Gaz
2Blue Print Clutch Kit - ADN13069 Empty Re: Blue Print Clutch Kit - ADN13069 on 26th June 2016, 6:42 pm
Top post mate,
thumbsup
I always assumed replacement parts are size for size, but just goes to show you have to check everything.
3Blue Print Clutch Kit - ADN13069 Empty Re: Blue Print Clutch Kit - ADN13069 on 26th June 2016, 8:41 pm
I don't look at pattern oem clutch in enough detail spot something like that, goes to show you really do need compare and check stuff in great detail.
Those clutches are Nippon Clutch Co units, never used one so interesting how good it is . Gave you a rep as good info and could save some hassle and will encourage us all check stuff well ...
4Blue Print Clutch Kit - ADN13069 Empty Re: Blue Print Clutch Kit - ADN13069 on 26th June 2016, 10:35 pm
Lot of work for a few mm of metal .... least it wasnt wrong with it other than it being to big ....
