Gtir Motorsport club » Tech room » Gearbox section » Pete (the box slayer) rebuild
Go to page : 1, 2, 3, 4, 5, 6, 7  Next
Go down  Message [Page 1 of 7]
1Pete (the box slayer) rebuild Empty Pete (the box slayer) rebuild on 5th July 2016, 8:26 pm
This post details Pete's gearbox rebuild from scratch and ill be following the official Nissan workshop manual line by line.
Please chip in with any advice or support as there's quite a bit of pressure to get this one right after the 7 previous failures. His luck's gotta change sometime  Laughing
Anyway all shaft assemblies are stripped and ready for inspection and measurement. Very Happy
2Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 5th July 2016, 8:50 pm
Looking forward to watching this thread Smile
3Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 5th July 2016, 10:08 pm
This will be like a gtir gearbox Haynes manual post thumbsup come on hurry up Laughing
4Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 6th July 2016, 6:18 am
Pete's replacement main shaft came yesterday, thanks Stu! Very Happy
Pete (the box slayer) rebuild Img-2011
Although it came out a failed box, it was because of the magnet breaking up and going through mesh , which is relatively soft and shouldn't have over stressed the teeth.
As shown below there's minor debris damage to the flanks but no signs of wear or cracking   Very Happy
Pete (the box slayer) rebuild Img_2051
The journals look good with only very minor wear.
The manual doesn't state a wear limit diameter for these journals which is surprising
Pete (the box slayer) rebuild Img_2052
5Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 6th July 2016, 11:13 am
You're welcome mate.
Hopefully its good enough to use.
All this technical stuff is way over my head lol
6Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 6th July 2016, 11:20 am
I think you have to also give a rep point for Neils wife she followed him around all day at Japfest 2 listening to him go on about shafts and needle bearings she is a trooper!
7Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 6th July 2016, 1:21 pm
This is going to be interesting! And like burrows said, this is basically going to be a full how to on the Gtir box!!
8Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 5:35 pm
You got ring-gear to go with the mainshaft .
How you looking for syncro parts & replacement par parts .
9Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 6:09 pm
@Mr B wrote:You got ring-gear to go with the mainshaft .
Im salvaging these parts from Pete's 2nd box which all look ok but ill be taking them to work next week to be measured aswell to make sure they're still within limits.
Pete is ordering new 1st and 2nd mainshaft gears from PAR in the next few weeks Very Happy
10Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 6:44 pm
I prefer a used mainshaft & ring-gear as a set over mixing used ones whenever possible .
11Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 7:17 pm
@Mr B wrote:I prefer a used mainshaft & ring-gear as a set over mixing used ones whenever possible .
I agree about matching sets where parts mate with each other.
By ring gear, do mean the reverse ring gear on the 1st/2nd synchro hub?
12Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 7:56 pm
fd ring-gear
13Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 8:46 pm
@Mr B wrote:fd ring-gear
I was going to speak to Pete about this but first he needs the green light on Stu's main shaft which im getting measured next week.
14Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 7th July 2016, 9:08 pm
What's the issue?
15Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 5:51 am
@PartyPete wrote:What's the issue?
I want to measure the journal diamters and gear bores so when assembled id know the play from any wear.  study
Like i said the journals look fine but i just want to know.
The manual doesnt state a 'wear' diameter for the journals, but just tells you to inspect for signs of wear, Suspect
16Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 6:31 am
It doesn't state any wear limits but tells you to check for wear scratch ....makes sense Razz
17Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 12:15 pm
Generally as any wear will be visual scoring or lubrication/heat damage over excessive clearance. Would of been nice have factory clearances in manual.
Was much easier doing boxes few years back when plentiful and very good order full spare box easily sourced .
Has Stu got ring gear paired with that shaft ...
18Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 7:20 pm
I don't know you've been dipping your shaft Stu but a load of black jizz came out of it Shocked
Pete (the box slayer) rebuild Img_2053
Now it's all scrubbed The journals look good as do the flanks.
Pete (the box slayer) rebuild Img_2054
Pete (the box slayer) rebuild Img_2055
The input shaft looks good except for the heavy contact on the non drive flanks from where it was backward driven . Also there's a small dink in the tip which needs polishing out. It can also be seen in the photo below.
Pete (the box slayer) rebuild Img_2056
The good news everything's ready to measure. Also there's a spare 1st synchro ring Pete so you might be able to get a refund.
Pete (the box slayer) rebuild Img_2057
19Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 7:31 pm
@Mr B wrote:Generally as any wear will be visual scoring or lubrication/heat damage over excessive clearance. Would of been nice have factory clearances in manual.
If the ring gear is the diff then thats in my gearbox.
@Cosmic73 wrote:I don't know you've been dipping your shaft Stu but a load of black jizz came out of it Shocked
I guess all that black shite is from the magnet exploding?
Glad my gearbox builder used the shafts out of my spare box for my rebuild lol
20Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 9:28 pm
Did somebody say refund? Haha need all the extra pennies I can get
21Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 9:32 pm
I wouldn't know where to start with that box of bits!
22Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 9:41 pm
@burrows1980 wrote:I wouldn't know where to start with that box of bits!
Its all labelled, plus i photographed each step.
Yes, refund Pete, how much was your synchro?
23Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 8th July 2016, 9:44 pm
Can't remember 100% but sure it was around £40
24Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 9th July 2016, 6:29 am
Can I be a twat lads inc this post I am writing this thread is off track already. Needs to be solid gear box build thread from start ie strip down to rebuild in order inc pics only and any comments reps etc general chat can be added to the other one. Even the cleaning process tools used to measure parts what to look for just pure fact with questions on a different thread
Not meaning to sound funny but it's great your willing to do one even it it helps others understand what to ask a builder for on there builds. Just would love to see a pure fact file
25Pete (the box slayer) rebuild Empty Re: Pete (the box slayer) rebuild on 9th July 2016, 9:00 am
@johnny gtir wrote:Can I be a twat lads inc this post I am writing this thread is off track already. Needs to be solid gear box build thread from start ie strip down to rebuild in order inc pics only and any comments reps etc general chat can be added to the other one. Even the cleaning process tools used to measure parts what to look for just pure fact with questions on a different thread
Thats a fair point but the workshop manual is pretty good at detailing the strip down and rebuild (inc diagrams) anyway and all im doing is following it step by step.
Also its more complicated because theres was no clean strip down, just a salvage from 3 failed boxes.
Once its all done, i can create a new post that will be a pure and concise strip and rebuild. I can use the strip down photos from my gearbox, and rebuild photos from mine and Petes gearbox without the the banter.
Right now, i want everyones comments for 2 reasons;
Most of the parts being salvaged are from failed gearboxes and may be compromised, so its higher risk of future failure,
If Petes box does fail again, ill get blamed and i dont want to be slagged off for things i shouldve done by people that didnt pipe up at the time.
Im not charging anything thing for this, and id be offended if Pete  offered me something. I just want to help someone who's had rotten luck by doing the best i can according to the book.
Back to top  Message [Page 1 of 7]
