Gtir Motorsport club » General Discusion » Gtir related Discussion » S13 flywheel
S13 flywheel
1S13 flywheel Empty S13 flywheel on 6th July 2016, 8:39 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Im looking for a light weight flywheel at present. Will an s13 flywheel fit on the R? The one I've seen is advertised as an s13,s14 sr20det flywheel. I've read something on another site to say it will. But just want to check it with you guys before I purchase. I have read a thread on here that said s13 clutches will fit aswell so it makes sense flywheel will also??
2S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 8:46 pm
I believe the flywheels are interchangeable, de are different though Smile
3S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 8:51 pm
Isnt the crank ends different size ????
4S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 8:55 pm
Yeah thought the bolts are bigger on the 54c.
5S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 8:59 pm
As far as I'm aware 54c got 12mm flywheel bolts and s body are smaller
6S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 9:31 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Yes that's looks to be correct. Just looked at some arp flywheel bolts for rnn14 and it says they won't fit sr20det. Thanks for that anyway lads.
7S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 9:33 pm
Sorry they are bigger, the R has 11mm bolts. But from what I remember the flywheels are interchange in terms of size etc other than redrill.
8S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 9:43 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Ok. So in theory you could just redrill the holes on an s13 flywheel. The s13 bolts are 10mm.
9S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 9:52 pm
http://www.rhdjapan.com/jun-light-weight-flywheel-standard-nissan.html
How about this one?? Would sourcing S13 flywheel be cheaper??
10S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 10:16 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Id been looking at fidanza ones. Waiting for Part box to get back to me with a price. Seen one on ebay new for 410quid. Abit more than I wanted to pay.
Then I seen the competition clutch one for the s13. The ultra light. It weighs 4.6kg half the weight of other lightweights I'd been looking at. And it's 250quid. That was the appeal.
Looks great too. Pointless I know.
Will check the jun one. Thanks
11S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 10:31 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Ok it's 290 that jun one. 360 with shipping from the homeland. Do u get hit with import tax aswell from Japan? At checkout it just says 10 charge and 56quid DHL delivery. I'm thinking that could include import tax??
12S13 flywheel Empty Re: S13 flywheel on 6th July 2016, 10:37 pm
You will pay import tax on top unfortunately not sure how much will be that
13S13 flywheel Empty Re: S13 flywheel on 7th July 2016, 4:01 am
Is easy enough redrill other flywheels, don't think I would go as light as 4.6, pending on what you doing .  6.5 is light enough for most ...
14S13 flywheel Empty Re: S13 flywheel on 7th July 2016, 9:07 am
mreguest
mreguest
coincidentally...
http://www.gtir-motorsport-club.com/t6728-lightweight-flywheel-competition-clutch#99531
It's just short of 5kg. I really like it. It was about £250, (http://www.competitionclutch.co.uk/csindex.php?vn=nissan) I think it was 2-760T-STU - If you want one ask the garage I got it from as they are a comp dealer.
15S13 flywheel Empty Re: S13 flywheel on 7th July 2016, 10:48 am
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Thanks for that. Very interesting.
That's the part code I've been looking at. Think I'm gonna give it a go.
Where did u order from mreguest?
16S13 flywheel Empty Re: S13 flywheel on 7th July 2016, 11:33 am
mreguest
mreguest
@TOMMYPRU.GTIR wrote:Thanks for that. Very interesting.
Hello,
was in my thread:
ordered from here:
http://www.euro-spec2000.co.uk/
Speak to Ben or Kerry. Not sure what they do about postage but worth a call, they can probably get comp to deliver direct to you?
It's just around the corner from my house so I picked it up, drilled it out with a hand drill and used my old flywheel as a vertical guide. Remember to drill slowly with a good drill bit and plenty of oil. Or if you have a pillar drill then you'll probably get through no problem...
Good luck!
Adam
17S13 flywheel Empty Re: S13 flywheel on 7th July 2016, 3:57 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Thanks for that Adam.
Will let u know results when I eventually get it in the car.
