Gtir Motorsport club » General Discusion » Gtir related Discussion » is a gt2871 a roller bearing turbo
1is a gt2871 a roller bearing turbo Empty is a gt2871 a roller bearing turbo on 18th July 2016, 1:08 pm
Just read a post about turbos and someone said his gt2871ain't roller bearing. .
Got me wondering if mine is roller bearing
2is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 2:23 pm
Yeah should be from what I believe! I have a GT2860RS and that's roller bearing. Should here it run down after engine switch off
3is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 3:00 pm
gt2871 ...... gt2871R the r stands for rollerbearing
4is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 3:39 pm
Mine is. You can hear the turbine still spinning when you turn the engine off.
5is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 4:31 pm
Do they do a gt2871 without a roller bearing
6is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 4:39 pm
You can, but only if it's one of those Chinese turdo's
7is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 6:20 pm
garrett do 'as said' a 2871 journal bearing turbo or 2871r which is roller bearing
so ideally you need to check id numbers marked on plate
but you should be able to tell by the way the compressor wheel spins if you spin it up with your fingers
8is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 7:28 pm
If you sneeze on it and it spins it's a roller turbo... Also if you switch engine off and you still can hear it spinning (sort of humming noise)
http://www.turbobygarrett.com/turbobygarrett/garrett_nomenclature
http://www.turbodynamics.co.uk/technical/technical-info/garrett-turbo-tech/garrett-gt-vs-t-series/
9is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 8:14 pm
I bought it from someone on here who upgraded to a 3071 but not sure if it's roller bearing .. I've checked emails to see if I can figure out who I bought it from but I can't remember .. who was it that had the mag feature recently?
10is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 8:16 pm
@GTI-R US wrote:garrett do 'as said' a 2871 journal bearing turbo or 2871r which is roller bearing
I thought the GT2860/71/76 were all roller bearing, everyday's a school day! Very Happy
11is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 8:17 pm
@ROB_IOW wrote:I bought it from someone on here who upgraded to a 3071 but not sure if it's roller bearing .. I've checked emails to see if I can figure out who I bought it from but I can't remember  ..  who was it that had the mag feature recently?
Was it Party Pete?
12is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 8:36 pm
Either way rollers are good but unless it's uprated bearing cage etc don't last long as cage melts. Sometimes oil entry gives it away as it has a restrictor built into it (not all)
13is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 18th July 2016, 8:40 pm
Yes party Pete ..
It was his old turbo
14is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 19th July 2016, 6:16 am
A Guide to Garrett’s "GT" Model Numbers
is a gt2871 a roller bearing turbo Garrett_nomenclature
15is a gt2871 a roller bearing turbo Empty Re: is a gt2871 a roller bearing turbo on 20th July 2016, 8:46 am
I am pretty sure it was brought from the states, I cant remember what it said on the receipt but there was an invoice in the cars folder of stuff when I had it. I think he had purchased it when he rebuilt the engine. It was abut £700/800 from memory but that was a few years ago! maybe Pete still has the documentation to have a look.
