Gtir Motorsport club » General Discusion » Gtir related Discussion » 3071 turbo manifold?
13071 turbo manifold? Empty 3071 turbo manifold? on 25th July 2016, 4:22 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Quick question
U guys who've fitted 3071 or any 30 series turbos. Do you have to have a t3 manifold or have any of you used the t2 to t3 adapters. Do those adapters defeat the object of putting on a 3071 when you only have a t2 manifold?
23071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:09 pm
As far as I know there are two versions of Gt3071R one with T3 flange which won't bolt on stock mani and one with T25 flange which does bolt to stock mani you'll need to grind few casting mark off and depending on what actuator you'll get you might to modify bracket for it. I've recently bolted one of those on my mates pulsar. You'll need braided oi and water lines too as stock won't fit and you might need to modify oil drain. While you're at it it's wise to get your exhaust mani ported too.
33071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:18 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Thanks pal. Ive got a t2 manifold already. Jap speed one. Do u mean I need to port the manifold itself if it was a stock item.
43071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:22 pm
I've replaced mates manifold... He had Japspeed which has cracked milion times an in the end it flange has warped... So I wouldn't recommend putting one of those on and prolly load of people will tell you the same. Get standard cast one ported granted tubular would be easier to fit but it'll give you no end of trouble.
53071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:34 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Ok. Thanks again. Got it now.
The jap speed one I got with the engine i bought. Id heard they were crap. Thats not goin on then. Just still figuring out what set up I'm gonna go with at the mo. And getting my head round it all.
Can u get t3 manifolds for the R or are they mostly custom jobs?
63071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:38 pm
I'd say decent T3 would be either custom/not cheap or something like 6 Boost which is not rly cheap either lol any cheap ebay will give you loads of trouble bud.
73071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:40 pm
You could get a t3 flange and have it tig welded onto the stock mani .... just throwing that out there Wink
83071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:42 pm
True that, and adapter for external wastegate too...
93071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:50 pm
Yeah mike ive seen quite a few stock manifolds with external wastegate pipe grafted on ....
103071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 7:56 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Could you externally wastegate a stock turbo by welding the flap shut. Wat are the advantages of external wastegate apart from the awesome noise?
113071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:02 pm
Whytie
Whytie
You can weld the pennie shut no probs
123071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:06 pm
I believe you'd get less boost creep and less boost spikes (generally better boost control as it flows better) if you're after noise well I've got internally wastegated gt28 and I've got screamer pipe on it too Razz
133071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:13 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Ok got it.
Your sceamer. Is that done from the turbo elbow point then?
143071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:18 pm
Yup I've got am performance elbow+downpipe (one on the top)
3071 turbo manifold? S-l40010
153071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:20 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
Wow. that must be a dirty noise.
163071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:22 pm
It's on a daily car mate piss taker
173071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:39 pm
Dirtier is better Laughing
183071 turbo manifold? Empty Re: 3071 turbo manifold? on 25th July 2016, 8:48 pm
193071 turbo manifold? Empty Re: 3071 turbo manifold? on 26th July 2016, 7:05 pm
Ricks1983
Ricks1983
Or you e got this and it's ideal for external waste gate aswell
http://www.jperformance.co.uk/nissan-pulsar-gtir-sr20-n14-cast-iron-turbo-manifold-p-668.html
203071 turbo manifold? Empty Re: 3071 turbo manifold? on 26th July 2016, 7:32 pm
Doesnt it top mount it .....???
213071 turbo manifold? Empty Re: 3071 turbo manifold? on 26th July 2016, 8:28 pm
TOMMYPRU.GTIR
TOMMYPRU.GTIR
I like the look of that. I will call them tommorow but I would think it top mounts from the look of it. Good price aswell. And T3. And it will be mega strong. Top find that ricks. Thanks
223071 turbo manifold? Empty Re: 3071 turbo manifold? on 26th July 2016, 9:07 pm
Dobby had one of those cast top mounts on his car with a gt3076r think it got to maybe 450bhp and topped out but thats quite a healthy figure really!
