Gtir Motorsport club » Gallery » Members gti-r's » Red Gti-r DIEGSR - Complete Rebuild
1Red Gti-r DIEGSR - Complete Rebuild Empty Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 10:57 pm
gtircrazy
Hi All,
Some of you may have seen this build thread, but with sites closing down i thought i better move it to a few more locations, also i will be adding to it shortly as i have done a lot more work on this car over the last year.
Since about september 2009 i started doing my partners gti-r up which had been sitting infront of the house for three years.
First things first the engine was toast. Some clown shoe's had put valve grind into it with an oil change.. You can imagine the results.
So I was on the hunt for a new engine. After 3-4 months of looking i found one i thought was the business. 180psi of compression on all four cyliners. MINT!!
So out came the old engine.
And in with the new one.
Once we put the new engine in we poped the rocker cover off.
And to my shock the intake cam was completly rooted. Looks as though one of the top oil sqirters had blocked and starved the head of oil..
Great!
So out with the cams, rocker arms and shims..
I re-drilled the oil sqirters to a slightly larger diamater and blew all the rubbish out of them with a air compressor.
So i found some second hand cams in the garage with some rockers and put them back in. After some very painful Re-shimming the head was good to be started again.
As you can imagine after sitting in the weather for three years untouched just about everything was stuffed on this car.. So alot of stuff was just replaced. c.v joints and boots, shocks, a few bushes. was a nightmare.
To top things off once we tried to start it it would not go..
After some mucking around i decided to go see Barry at MSM motorsport in Penrose Auckland if theres something i cannot work out on a nissan I know Barry is the man to see. Top bloke recommend him to everyone.
After a swift wack around the head from him we descovered that the cam timing was out by 2 teeth..
Doh!
So after re-doing that.. (you know what that means getting that dam cam chain tensioner out and back in..) the car sprang to life..
Followed by massive clouds of white smoke.. expected though the turbo had been sitting for 3 years. On inspection the oil seals had gone. So i decided to give DSR turbos ago..
Turned out to be a bad idea .
But everything was going and in the midst of it i had installed
550cc injectors
Q45 MAF
my old PLMS daughter board into the ECU with 4 way map switcher
greddy profect B boost controller
Apexi air filter
Jun Light wieght flywheel
5 puk carbon kevlar clutch and uprated 2300ibs pressure plate
Front mount with custom piping
3inch exuast with 3inch custom downpipe
DSR 380 turbo
Polished top plenuim
HKS limited edition B.O.V
Plus a few more things iv probably forgotten about.
So it was off for the tune.
We later found that the DSR turbo had a manufactures fault and would not boost past 10psi..
But i was entered in the 4 & Rotorary Nationals 2010 so we tuned it the best we could and went racing... well driving 400m in a streight line.
Red Gti-r DIEGSR - Complete Rebuild Removalofoldengine
The car with the old engine about to be removed above.
Red Gti-r DIEGSR - Complete Rebuild OldEngineOut
Engine all removed above.
Red Gti-r DIEGSR - Complete Rebuild NewFlyWheel
Jun Light Weight Flywheel
Red Gti-r DIEGSR - Complete Rebuild NewClutch-1
New Clutch
Red Gti-r DIEGSR - Complete Rebuild CamsOut
Head Stripped and Cams out after damage found on new engine.
Red Gti-r DIEGSR - Complete Rebuild DamagedCam
One of the damaged lobes from the intake cam
Red Gti-r DIEGSR - Complete Rebuild NewCamsInandHeadRe-Shimmed
New cam in place
Red Gti-r DIEGSR - Complete Rebuild AllfinishedandRunning
Car all back together and going!
Red Gti-r DIEGSR - Complete Rebuild NewPicture
Running at the 2010 4 and rotarys
So ended up doing 13.7 as the best time in the car with the rubbish turbo.
So i went and bought a Garrett Gt25/40.
On some real good inspection on the hoist i found that the shell was developing some good rust in the wheel arches. Along with the side of the car and also a old weld repair on the rear quater was starting to come through..
I though stuff this and purchased a new shell.
The Shell used to belong to a mate who poored over 60k into the car i think. I was lucky enough to get a ride in it before he sold it.
The car was stolen from the new owner and stripped.
But the shell was recovered.
I picked it up in the condition below
Red Gti-r DIEGSR - Complete Rebuild 130959329_full
Red Gti-r DIEGSR - Complete Rebuild 130959339_full
Red Gti-r DIEGSR - Complete Rebuild 130959358_full
Red Gti-r DIEGSR - Complete Rebuild 130959304_full
So the ground up rebuild begain. Two shells one set of running gear and a bucket of money...
So the swap over begins.
Ok the strip down.
8.50am i arrived at my MSM Automotive Limited with a running driving road legal Gti-r
By 5.30pm we had fully stripped it down to the bare shell.
Red Gti-r DIEGSR - Complete Rebuild Internet1
Red Gti-r DIEGSR - Complete Rebuild Internet2
Red Gti-r DIEGSR - Complete Rebuild Internet3
Red Gti-r DIEGSR - Complete Rebuild Internet8
Red Gti-r DIEGSR - Complete Rebuild Internet7
Red Gti-r DIEGSR - Complete Rebuild Internet4
Red Gti-r DIEGSR - Complete Rebuild Internet5
Red Gti-r DIEGSR - Complete Rebuild Internet6
Special note: DSR turbo thank F&*k this came off the car! worst turbo i have ever had!
Red Gti-r DIEGSR - Complete Rebuild Internet9
Red Gti-r DIEGSR - Complete Rebuild Internet10
Red Gti-r DIEGSR - Complete Rebuild Internet11
Red Gti-r DIEGSR - Complete Rebuild Internet12
[/img]https://2img.net/h/i28.photobucket.com/albums/c241/the_magic_touch/internet14.jpg[/img]
Red Gti-r DIEGSR - Complete Rebuild Internet16
The New Shell
So the rebuild of every component in the car starts..
First up was the gearbox and head.
Red Gti-r DIEGSR - Complete Rebuild Image146-1
Red Gti-r DIEGSR - Complete Rebuild Image167-1
Turns out i need 1st, 2nd, 3rd, 4th, and 5th gear syncro's and 2nd gear hub.
Ouch!
Red Gti-r DIEGSR - Complete Rebuild Image000-1
Red Gti-r DIEGSR - Complete Rebuild IMG_1717
Red Gti-r DIEGSR - Complete Rebuild IMG_1715
New Bearings and syncros arrive. Also second gear hub. Nissan had just raised there Gti-r gearbox bits in price as well.
Sent the rear subframe off to be sandblasted and reconditioned. Is now fully rust coated appoxied and painted. Looks great! Also added some full aluminum rear subframe mounts!
Red Gti-r DIEGSR - Complete Rebuild Image164-1
Red Gti-r DIEGSR - Complete Rebuild Image165
So the head was popped off and we started to disassemble it.
Red Gti-r DIEGSR - Complete Rebuild Image171
Red Gti-r DIEGSR - Complete Rebuild Image172
Red Gti-r DIEGSR - Complete Rebuild Image176
Red Gti-r DIEGSR - Complete Rebuild Image174
[img][/img]
So the head was stripped so i started to assemble some bits and peices for it.
272 degree Franklin Cams
Red Gti-r DIEGSR - Complete Rebuild Image004
Adjustable cam gears
Red Gti-r DIEGSR - Complete Rebuild Image003
New Valve steam seals
Red Gti-r DIEGSR - Complete Rebuild Image020-1
Manley uprated valve springs
Red Gti-r DIEGSR - Complete Rebuild Image002-1
Cometic head gasket
Red Gti-r DIEGSR - Complete Rebuild Image008
Bought some ARP head studs and fitted them into the block
Red Gti-r DIEGSR - Complete Rebuild Image006
Red Gti-r DIEGSR - Complete Rebuild Image173
Ok so things were happening
Rebuilt start motor
Rebuilt steering rack
Rebuilt power steering pump
New Water pump
Oil pump checked and cleaned
Head removed
Skimmed
Valves cleaned and lapped into there seats
New uprated Valve springs fitted
New APR head studs fitted
New cams fitted
New tensioner fine tooth fitted
Whole under side completed bar the calipers
New rear Teflon braided lines for the rear fuel tank all cut and ready to go.
This stuff is about twice the price of braided line but for a reason its sooo much better.
Red Gti-r DIEGSR - Complete Rebuild Image016
Red Gti-r DIEGSR - Complete Rebuild Image015
https://www.facebook.com/gtirnz
2Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 10:58 pm
gtircrazy
Cleaned, Primered and painted the whole under side of the car myself.. What a mission
Red Gti-r DIEGSR - Complete Rebuild Image004-1
Steering Rack after rebuild
Red Gti-r DIEGSR - Complete Rebuild Image011
New ball joints in front arms
Red Gti-r DIEGSR - Complete Rebuild Image005-1
One of the many to come brackets that i polished
Red Gti-r DIEGSR - Complete Rebuild Image003-1
Lapping in the valves...c**t of a job.
Red Gti-r DIEGSR - Complete Rebuild Image034
Head having its final touqe down to the block with Steel head gasket
Red Gti-r DIEGSR - Complete Rebuild IMG_1748
Red Gti-r DIEGSR - Complete Rebuild IMG_1750
Top half of the plenuim coated in thermacoat heat protection
Red Gti-r DIEGSR - Complete Rebuild Image021
Water lines coated in the same heat protection coating
Red Gti-r DIEGSR - Complete Rebuild Image022
Rear subframe bolted into place
Red Gti-r DIEGSR - Complete Rebuild IMG_0939
Aluminum mounts in the rear subframe
Red Gti-r DIEGSR - Complete Rebuild IMG_0940
Bolts and bits and peices coming back from being Re-nickle coated.
Red Gti-r DIEGSR - Complete Rebuild IMG_0943
Brand new bolts for the more generic stuff
Red Gti-r DIEGSR - Complete Rebuild IMG_0944
Steering rack back in place with nolathane mounts
Red Gti-r DIEGSR - Complete Rebuild IMG_0947
New Tensioner in, Adjustable cam gears in, 272 brand new cam shafts in, brand new uprated valve springs in, New steel head gasket in.
Red Gti-r DIEGSR - Complete Rebuild IMG_0951
Plenuim coming back together with the throatle bodys that i hand polished.. 70 hours later
Red Gti-r DIEGSR - Complete Rebuild IMG_0970
Reconditioned power steer pump back on
Red Gti-r DIEGSR - Complete Rebuild IMG_0954
Polished diff rear housing and painted diff casing back together and ready to go in. Once again i hand polished the rear diff casing.. 30 hours later..
Red Gti-r DIEGSR - Complete Rebuild IMG_0957
Jam racing coilovers having a touch up
Red Gti-r DIEGSR - Complete Rebuild IMG_0959
Rear diff in the subframe
Red Gti-r DIEGSR - Complete Rebuild IMG_0960
Painted front control arms and hubs
Red Gti-r DIEGSR - Complete Rebuild IMG_0963
Rear brake disks DBA4000 series.
Red Gti-r DIEGSR - Complete Rebuild IMG_0966
Custom made muffler for the rear of the gtir will flow really well but make the car legel for the roads.
Red Gti-r DIEGSR - Complete Rebuild IMG_0995
Plenuim on the engine bolted down
Red Gti-r DIEGSR - Complete Rebuild IMG_0979
Red Gti-r DIEGSR - Complete Rebuild IMG_0974
Water pipes fitted and heat wrapped to try and avoid heat soak.
Red Gti-r DIEGSR - Complete Rebuild IMG_0977
Red Gti-r DIEGSR - Complete Rebuild IMG_0978
Painted vacum canaster and all new vacum line at the back, Plus oil filter relocation kit fitted.
Red Gti-r DIEGSR - Complete Rebuild IMG_0980
And the most fun part working out and reshimming the F^%king head
Red Gti-r DIEGSR - Complete Rebuild IMG_0997
3Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 10:59 pm
gtircrazy
Jun Flywheel installed
Red Gti-r DIEGSR - Complete Rebuild IMG_1000-1
Brand new exceddy clutch kit installed
Red Gti-r DIEGSR - Complete Rebuild IMG_1002
Red Gti-r DIEGSR - Complete Rebuild IMG_1003
Gearbox going onto the engine
Red Gti-r DIEGSR - Complete Rebuild IMG_1004-1
Red Gti-r DIEGSR - Complete Rebuild IMG_1005-1
Polished distrubutor and coil bracket on
Red Gti-r DIEGSR - Complete Rebuild IMG_1013
Polished alternator done also nickle coated the pulley as well and bolt.
Red Gti-r DIEGSR - Complete Rebuild IMG_1021
Braided line on, loom on
Red Gti-r DIEGSR - Complete Rebuild IMG_1017
Engine in ;D
Red Gti-r DIEGSR - Complete Rebuild IMG_1034
Red Gti-r DIEGSR - Complete Rebuild IMG_1038
Red Gti-r DIEGSR - Complete Rebuild IMG_1039
New Stainless Alen key bolts and washers to replace all the gaurd bolts
Red Gti-r DIEGSR - Complete Rebuild 169022_480753291570_723416570_6280525_6806051_n
Red Gti-r DIEGSR - Complete Rebuild Be2RwCGkKGrHqQOKjYEr0g5g6dBK-8C73s-_12
The person who stole the car had fun cutting every single wire in the car...Good on you mate!
Red Gti-r DIEGSR - Complete Rebuild 163087_480753341570_723416570_6280527_6563057_n
Setrab oil cooler..
Red Gti-r DIEGSR - Complete Rebuild 162976_480753466570_723416570_6280533_1799627_n
Front underside so far
Red Gti-r DIEGSR - Complete Rebuild 164855_480753001570_723416570_6280513_3246401_n
Back underside
Red Gti-r DIEGSR - Complete Rebuild 168643_480752731570_723416570_6280503_397797_n
New longer wheel studs
Red Gti-r DIEGSR - Complete Rebuild 166512_480753116570_723416570_6280518_3194166_n
Lengthened the injector loom and put sard plugs on
Red Gti-r DIEGSR - Complete Rebuild 166859_480753201570_723416570_6280522_1821455_n
4Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:00 pm
gtircrazy
Underside completly finished
Red Gti-r DIEGSR - Complete Rebuild 162654_484802211570_723416570_6345318_6270519_n
Red Gti-r DIEGSR - Complete Rebuild 164193_484802226570_723416570_6345319_2788782_n
Cars first night of starting!
Red Gti-r DIEGSR - Complete Rebuild 179083_484802786570_723416570_6345338_7361290_n
Red Gti-r DIEGSR - Complete Rebuild 169009_484802891570_723416570_6345344_1639077_n
Hood lining done as well
Red Gti-r DIEGSR - Complete Rebuild 165555_480753386570_723416570_6280530_5112907_n
5Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:00 pm
gtircrazy
Ok so in between here and being finished there are not alot of pictures as it was a very mad rush to have the car ready for the 2011 4 and rotarys show and drags.
We made it though
Red Gti-r DIEGSR - Complete Rebuild DSCF3436
Red Gti-r DIEGSR - Complete Rebuild DSCF3428
Red Gti-r DIEGSR - Complete Rebuild Gtirowers
Red Gti-r DIEGSR - Complete Rebuild 164860_10150127366948582_774433581_7866858_1320717_n
Red Gti-r DIEGSR - Complete Rebuild 166834_10150127366983582_774433581_7866859_3225688_n
Red Gti-r DIEGSR - Complete Rebuild 167184_198528450161948_175759119105548_850175_4346043_n
Red Gti-r DIEGSR - Complete Rebuild 168782_10150127365343582_774433581_7866823_6992410_n
Unfortunilty the drags the next day didnt go so well. Blowing the ringlands on the first run causing the car to be parked up for the rest of the day... So engine out next week for a bottom end rebuild with some forged pistons.
Red Gti-r DIEGSR - Complete Rebuild DSCF3530
Red Gti-r DIEGSR - Complete Rebuild Fghfg
So the engine let go on 26psi on its first run down the drag strip. 7 months of hard work by me and my mates. Also MSM Automotive. The only thing we did not touch in the build was the bottom end as i have run Gti-rs with 500hp on stock bottom ends before. This one did not last so well though.
So the block has been removed and has been sent to Reg Cook. It will return good for 700hp.
The Damage
Red Gti-r DIEGSR - Complete Rebuild 198263_10150111072251571_723416570_6750989_6512747_n
Red Gti-r DIEGSR - Complete Rebuild Degthg
The ringlands just didnt like the boost... Stay tuned i will update this as the engine comes back together!
I have also fitted front and rear nismo mechanical lsds as well Smile
6Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:01 pm
gtircrazy
Well i imported a few bits from the UK at the start of the year:
AP 6 pot front calipers and 330MM twin hat rotors with machined adapter plates for the calipers
Full Carbon Fibre bonnet
Full Carbon Fibre wing
Carbon Wing mirrors
Carbon front grill
A custom gear stabilizer bracket to make selection more firm
Adjustable rose jointed sway bar links front
That all went well got them into the country.
Had the bottom end forged by reg cook. CP 87mm forged pistons, Eagle Rods with the 19mm bearings suited to gti-rs, all new nissan bearings, and all the other bits and bobs, oil pump done, oil galleries machined to flow more pressure, new water pump, new cam chain, crank was crack tested, engine blue printed and everything balanced.
Then i was lucky enough to stumble on a fully set up Jun cylinder head. So that is now fitted to the car with Jun everything. Stainless valves and retianers, Jun valve springs, Jun 268 cams, Jun adjustable cam gears. Should be good.
Imported the new Tomei head gasket from japan.
Imported three new gauges from USA Autometer.
Got all my interior carbon coated including rocker cover as well.
Now just got to put it all back together.
Red Gti-r DIEGSR - Complete Rebuild IMG00210-20111010-1601
Red Gti-r DIEGSR - Complete Rebuild IMG00191-20110914-1741
Red Gti-r DIEGSR - Complete Rebuild IMG00190-20110914-1741
Red Gti-r DIEGSR - Complete Rebuild IMG00188-20110914-1654
Red Gti-r DIEGSR - Complete Rebuild IMG00184-20110810-1759
Red Gti-r DIEGSR - Complete Rebuild IMG00179-20110810-1758
Red Gti-r DIEGSR - Complete Rebuild IMG00126-20110723-0907
Red Gti-r DIEGSR - Complete Rebuild IMG_2170
Red Gti-r DIEGSR - Complete Rebuild IMG_2166
Red Gti-r DIEGSR - Complete Rebuild IMG_2159
Red Gti-r DIEGSR - Complete Rebuild Email2
Red Gti-r DIEGSR - Complete Rebuild Email1
Then i had the issue of i didnt want this to happen:
Red Gti-r DIEGSR - Complete Rebuild Pulsarbox
So i did this:
Red Gti-r DIEGSR - Complete Rebuild Img8784b
Red Gti-r DIEGSR - Complete Rebuild Img8780x
Red Gti-r DIEGSR - Complete Rebuild Img8779
Also clutch pedal mod to stop the clutch pedal coming away from the fire wall.
Red Gti-r DIEGSR - Complete Rebuild Clutchbracket1
Red Gti-r DIEGSR - Complete Rebuild Clutchbracket2
Enjoy
7Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:02 pm
gtircrazy
Red Gti-r DIEGSR - Complete Rebuild IMG00022-20120320-1756
Fitted that up.
Fitted a set of these
Red Gti-r DIEGSR - Complete Rebuild IMG-20120328-00026
Got hold of one of these rear braces with pointless roll bar.
Red Gti-r DIEGSR - Complete Rebuild IMG-20120328-00031
Then it came time to fit the brakes.
Red Gti-r DIEGSR - Complete Rebuild DSCF4206
330mm rotors and 6 pot AP calipers. Needless to say they are large.
Red Gti-r DIEGSR - Complete Rebuild DSCF4202
In fact they are larger than my 15" wheels currently on the car..
Red Gti-r DIEGSR - Complete Rebuild DSCF4203
All the bolts had started to rust on the twin hats so decided to start replacing them.
Red Gti-r DIEGSR - Complete Rebuild DSCF4207
Fitted them to the car
Red Gti-r DIEGSR - Complete Rebuild IMG-20120328-00012
Red Gti-r DIEGSR - Complete Rebuild IMG-20120328-00011
Red Gti-r DIEGSR - Complete Rebuild IMG-20120328-00010
My partner bought down bacon and egg pie with MSM on the top. Nice
Red Gti-r DIEGSR - Complete Rebuild 549984_10150626545027283_687732282_9650369_1057297189_n
8Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:02 pm
gtircrazy
Well while it was on a hoist. Changed the rear diff over to a Nismo Mechanical item.
Red Gti-r DIEGSR - Complete Rebuild DSCF4190
Only picture i got whilst this was happening. Diff oil is messy stuff.
So with the brakes on.. i then had the issue of my old wheels did not fit.. ok time to start looking for some new ones.
I hate wheel shopping!!
Started with some Enkei racing wheels. 4x100 38P 17x7.5
Red Gti-r DIEGSR - Complete Rebuild DSCF4214
Red Gti-r DIEGSR - Complete Rebuild DSCF4215
Red Gti-r DIEGSR - Complete Rebuild DSCF4216
They did not fit. Dam i liked the look of them.
So SSR Light weight wheels where up next. 4x100 38P 17x7.5
Red Gti-r DIEGSR - Complete Rebuild DSCF4219Red Gti-r DIEGSR - Complete Rebuild DSCF4220
Red Gti-r DIEGSR - Complete Rebuild DSCF4217
Needless to say they did not fit. Sad
Well ok,
How about some Rays 4x100 40p 17x7
Red Gti-r DIEGSR - Complete Rebuild DSCF4223
Red Gti-r DIEGSR - Complete Rebuild DSCF4222
They went on well. Only 5mm spacers needed to make them fit. Sat inside the guards and did not foul on the struts. Only trouble is i didn't like the look of them.
So..OZ Racing wheels, these where my second choice to buy. They were heavy but made well compared to some of the other wheels. 4x100 18x7 40p
Red Gti-r DIEGSR - Complete Rebuild DSCF4231
Red Gti-r DIEGSR - Complete Rebuild DSCF4239
Fitted and looked good, the only thing that bothered me was the weight. To heavy.
So Tried some Advanti light weight racing wheels. I liked them until i flipped them over and saw the nasty casting marks. No thanks looks weak.
Red Gti-r DIEGSR - Complete Rebuild DSCF4228
These would have been my first choice if they would have fitted. So nice. 5Zigen racing wheels 18x7.5 4x100 38p.
Red Gti-r DIEGSR - Complete Rebuild DSCF4233
Red Gti-r DIEGSR - Complete Rebuild DSCF4234
Red Gti-r DIEGSR - Complete Rebuild DSCF4236
No way where these going to fit though. without wide kitting the car and running 20mm spacers.
I then was given these to try.. was not that keen on them. But they were so light. Forged, expensive but made for racing. Enkei wheels, 17x7 40p 4x100.
Red Gti-r DIEGSR - Complete Rebuild DSCF4249
Red Gti-r DIEGSR - Complete Rebuild DSCF4247
Red Gti-r DIEGSR - Complete Rebuild DSCF4259
When put on they bolted up perfectly. We can almost get away with running no spacers at all. 5mm spacers will be run to start with though.
So they were bought, Toyo T1r tires fitted.
And here is what is currently on the front to move the car around the workshop. 15mm spacers required.
Red Gti-r DIEGSR - Complete Rebuild DSCF4243
9Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:03 pm
gtircrazy
Ok so wheels and brakes are done. Fluids in brakes bleed. Can't wait. Just a few small things to finish off and we are away!!!.
Red Gti-r DIEGSR - Complete Rebuild DSCF4003
Red Gti-r DIEGSR - Complete Rebuild DSCF4005-1
Red Gti-r DIEGSR - Complete Rebuild DSCF4006-1
Red Gti-r DIEGSR - Complete Rebuild DSCF4008
This is where i am currently at in the build as of the 12/4/2012. Hope you all like my build so far. Smile
10Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:04 pm
gtircrazy
Another night another step in the right direction.
Shims checked, valve clearance checked, dash installed gauges wired up. Gearbox brace fitted fully. The final touches tomorrow will be engine oil, radiator fluid, battery. Start time!!
Red Gti-r DIEGSR - Complete Rebuild DSCF4012
Red Gti-r DIEGSR - Complete Rebuild DSCF4017
Red Gti-r DIEGSR - Complete Rebuild DSCF4019
Red Gti-r DIEGSR - Complete Rebuild DSCF4020
Red Gti-r DIEGSR - Complete Rebuild DSCF4021
Red Gti-r DIEGSR - Complete Rebuild DSCF4024
Red Gti-r DIEGSR - Complete Rebuild DSCF4025
Red Gti-r DIEGSR - Complete Rebuild DSCF4028
Red Gti-r DIEGSR - Complete Rebuild DSCF4030
Red Gti-r DIEGSR - Complete Rebuild DSCF4031
11Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:07 pm
gtircrazy
First start up video
https://www.youtube.com/watch?v=fO6hW4Lo0sA&feature=youtu.be
How the carbon affect was done:
https://www.youtube.com/watch?v=iP7BKHU4WUc
So
got the car going, warranted, registered its all ready to be driven. So took it home to put in the garage.
[Wink]
Has not been home in 2 years. Nice to see another gti-r sitting in the garage again.
Photo of the head with rocker cover off.
Red Gti-r DIEGSR - Complete Rebuild DSCF4057
One of the rear nissan brace and over head loop..
Red Gti-r DIEGSR - Complete Rebuild DSCF4052
Quick shot of the inside
Red Gti-r DIEGSR - Complete Rebuild DSCF4053
Just before the drive home
Red Gti-r DIEGSR - Complete Rebuild DSCF4065
Back home with the bumper back on.
Red Gti-r DIEGSR - Complete Rebuild DSCF4104
Red Gti-r DIEGSR - Complete Rebuild DSCF4102
In the garage
Red Gti-r DIEGSR - Complete Rebuild DSCF4097
Red Gti-r DIEGSR - Complete Rebuild DSCF4109
12Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:09 pm
gtircrazy
A video a mate made over the 2011 show and drag weekend when it blew up.
https://www.youtube.com/watch?v=LCKxCzJ0q_M
And my youtube channel if anyone wants to subscribe.
https://www.youtube.com/user/gtircrazy/videos
13Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:18 pm
Wow!
What an impressive build.
I knew you had done a lot to the car but didn't realise it was this intense!
Stunning car and build to say the least.
14Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 25th July 2016, 11:23 pm
Hey dude I've seen this somewhere else great build good to have you on board
15Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 26th July 2016, 12:26 am
Such a fan of this car, brilliant build thumbsup
16Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 26th July 2016, 11:20 am
Welling_AL
Welling_AL
Wow - Wow - Wow - Hats off Sir - that is one awesome car you have there !
What a journey too - thanks for sharing !
17Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 27th July 2016, 9:39 am
Incredible thumbsup
18Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 27th July 2016, 11:22 am
gtircrazy
Thanks for the kind comments guys. It really was a labour of love at the time.
19Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 27th July 2016, 12:38 pm
Great thread thanks for sharing
20Red Gti-r DIEGSR - Complete Rebuild Empty Re: Red Gti-r DIEGSR - Complete Rebuild on 14th August 2016, 10:51 pm
Amazing work mate, car looks spot on
