Gtir Motorsport club » Tech room » Help and Advice » Electrics problem
Electrics problem
1Electrics problem Empty Electrics problem on 24th August 2016, 12:28 am
RS-Bruvaz
My pride n joy arrived this morning. 1991 pulsar gti-r. Speedo not working? What will it be?
2Electrics problem Empty Re: Electrics problem on 24th August 2016, 8:34 am
typical area of fault is clock circuit board/plugs, dial motor or if fitted delimiter/converter unit/wiring fault .
In UK had trend for white dials and had a lot of faulty clocks after they been fitted .
Worth checking speedo sensor on gearbox for plug/wiring & signal output, can use an led as simple signal output testing tool . did have a post about it, if find it will add link .
link> http://www.gtir-motorsport-club.com/t6633-speedo
3Electrics problem Empty Re: Electrics problem on 24th August 2016, 3:09 pm
Does the trip meter count up? If that works then probably all OK and just a sticky speedo. If not then start checking all the above....
