Gtir Motorsport club » Tool section » Spot weld cutting
Spot weld cutting
1 Spot weld cutting on 27th August 2016, 8:14 am
Hey guys
Any recommendations on spot weld cutters and any advice on removing.
There are couple of things I need to do.
1 - I need to remove some rear rails from a floor section I have. I need to try and preserve the rails in good condition and also keep the floor intacted because I might need to replace some section of the floor in my R. I was going to try and grind the welds back and go from there.
2- Remove the rails of my car. I was thinking about going with something like this? Im guessing the cheaper ones dont last as long. Whats better, go cheap and use more, or get a more expensive one? Anyone have any experience using them?
2 Re: Spot weld cutting on 27th August 2016, 9:35 am
What I did was start to drill the spot weld with a 5 / 6mm drill bit creating a \/ in the weld, then grind the end of another 5 or 6mm hss drill bit basically creating an end mill drill, use that to finish it off.. Worked well for the hundreds I needed to do.
3 Re: Spot weld cutting on 27th August 2016, 10:41 am
^ good tip thumbsup
4 Re: Spot weld cutting on 27th August 2016, 11:17 am
I used a drill bit like this. Easier if you get a slightly larger diameter incase you miss the center.
https://www.google.com.au/search?q=spot+weld+drill+bit&client=ms-android-telstra-au&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwibsaLLu-HOAhUKopQKHYKtAUsQ_AUICCgC&biw=360&bih=511#imgrc=PfzyETothkNygM%3A
5 Re: Spot weld cutting on 27th August 2016, 9:22 pm
Thanks for the tips guys, Ill check them out Smile
6 Re: Spot weld cutting on 5th September 2016, 8:39 am
Picked up these ones, see how they go Smile
7 Re: Spot weld cutting on 5th September 2016, 10:15 am
Thats what i've used. Stole it out of my old bosses draw Smile
8 Re: Spot weld cutting on 15th November 2016, 6:15 am
Oz_e
These are good quality and readily available, come in 8 & 10mm and come in different variants depending on the power source used.
9 Re: Spot weld cutting on 15th November 2016, 7:25 am
The longer ones are much better, the shorts ones I got are difficult in some instances.
Btw welcome to the forum mate Smile
